Old 03-02-2018, 01:19 PM   #1
Ambush
Rawr!
Ambush's Avatar
Drives: Giulia Quadrifoglio, C8 Stingray
Launch Control on the SS Automatic
I read the instructions:
1. Sport or Track mode.
2. Double-tap the Traction Control button
3. Brakes hard to the floor.
4. Gas hard to the floor.
5. Let go of brakes.
On the automatic, all I get is burning rubber once step 4 is applied. I'm assuming there's no launch control on the automatic?
Current:
2023 Red Mist Corvette Stingray 2LT
2021 Trofeo White Alfa Romeo Giulia Quadrifoglio
Retired:
2018 Garnet Red Camaro 2SS
2014 Crystal Red Camaro RS
Ambush is offline   Reply With Quote
Old 03-02-2018, 01:20 PM   #2
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Here we go!
Wolvie70 is offline   Reply With Quote
Old 03-02-2018, 01:24 PM   #3
ShadySS
Drives: 2017 Hyper Blue SS
There is, I've used it many times, either it's malfunctioning or you're doing something incorrectly.
Does it say competitive mode on the dash when you double tap the traction control button?
ShadySS is offline   Reply With Quote
Old 03-02-2018, 02:14 PM   #4
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
From the Book:
Launch Control
A Launch Control feature is available, within Competitive Driving Mode, to allow the driver to achieve high levels of vehicle acceleration in a straight line. Launch Control is a form of traction control that manages tire spin while launching the vehicle. This feature is intended for use during closed course race events where consistent zero to sixty and quarter mile times are desirable.
Launch Control is only available when the following criteria are met:
•Competitive Driving Mode is selected.
•The vehicle is not moving.
•The steering wheel is pointing straight.
Manual Transmissions
•The clutch is pressed and the vehicle is in 1 (First) gear.
•The accelerator pedal is rapidly applied to wide open throttle.
The Launch Control feature will initially limit engine speed as the driver rapidly applies the accelerator pedal to wide open throttle. Allow the engine rpm to stabilize. A smooth, quick release of the clutch, while maintaining the fully pressed accelerator pedal, will manage wheel slip. Complete shifts are described in Manual Transmission.
Automatic Transmissions
•The brake pedal must be firmly pressed to the floor, equivalent to a panic brake event.
•The accelerator pedal is rapidly applied to wide open throttle. (If the vehicle rolls due to wide open throttle, release the throttle, press the brake pedal more firmly, and re-apply the accelerator to wide open throttle.)
After the vehicle is launched, the system continues in Competitive Driving Mode.
Competitive Driving Mode and Launch Control are systems designed for a closed course race track and not intended for use on public roads. The systems are not intended to compensate for lack of driver experience or familiarity with the race track.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 03-02-2018, 02:20 PM   #5
Gen6 softtop
Drives: Hyper blue 1ss convertible 6 sp
Probably not pressing brakes hard enough. I see it says equivalent to a panic stop
Gen6 softtop is offline   Reply With Quote
Old 03-02-2018, 03:09 PM   #6
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Smash the brake pedal hard. Go WOT fast and it should hold your car at 2k rpm
CruzySS is offline   Reply With Quote
Old 03-02-2018, 03:29 PM   #7
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Then hold on and enjoy the ride!
craigss50 is offline   Reply With Quote
Old 03-02-2018, 04:07 PM   #8
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
This, had trouble too my first time because punching a pedal through the floor is not natural lol.
On the other hand, I can beat LC every time launching manually.
Old 03-02-2018, 04:44 PM   #9
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Yes, until I was modded. Now I use LC every time at the track. Even tuned, it works.
Old 03-02-2018, 05:04 PM   #10
Ambush
Rawr!
Ambush's Avatar
Thanks for the input. I will try it again tomorrow.
Current:
Retired:
Old 03-02-2018, 05:22 PM   #11
wwiiavfan
Drives: 2017 1SS Hyper Blue
I’ve only tried it once, and it worked, but it bogged more than I like before it took off and left my intestines in the backseat. Haven’t had another chance to try it.
wwiiavfan is offline   Reply With Quote
Old 03-02-2018, 06:18 PM   #12
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Dumb question but do the V6 models have launch control?
Need4Camaro is offline   Reply With Quote
Old 03-02-2018, 06:21 PM   #13
Ambush
Rawr!
Ambush's Avatar
I believe that's a no. sorry.
Current:
Retired:
Old 03-04-2018, 12:52 AM   #14
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
This is the issue. Press the brake harder. I couldn't get it to work the first few tries. That was my solution.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
