View Poll Results: How much negative camber?
< -1.5 2 18.18%
> -1.5 4 36.36%
> -1.8 2 18.18%
≥ -2.0 3 27.27%
Voters: 11. You may not vote on this poll
Old 03-02-2018, 09:08 AM   #1
AdvanSuper
AdvanSuper's Avatar
Drives: 1SS 1LE Rapid Blue
How much negative camber have you gotten out of the front stock? SS non-1LE models
Title question and did you have to do anything excessive?
I'm stuck at -1.5 and I'm not thrilled about it. I was hoping to get as close to -2 as possible, but they shop gave up at -1.5. I trust they did everything within reason, but not anything some people would do themselves.
AdvanSuper is offline   Reply With Quote
Old 03-02-2018, 09:50 AM   #2
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
I was able to get -2 out of the front on mine.
Loosen the upper and lower bolt on the knuckle but don't take them off all the way. With an impact and a wrench on the upper nut and bolt push the top of the rotor in as far as you can go and when pushing hit the impact and lock it into place. the tighten the lower bolt. Thats how I managed to get -2.
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 03-02-2018, 09:55 PM   #3
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
Best my mechanic could to was -1.75 even Front. And it took two tries.
I guess there's some variability there in these cars.
HyperspaceTurd is offline   Reply With Quote
Old 03-07-2018, 01:22 AM   #4
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
-2.1° Front.
-2.4° Rear.
That's what my local Chev dealership was able to achieve. I asked that they try to get to -2.5° front and rear. They said they couldn't get more out of the front because the wheel was contacting the strut.
Not too sure about that but come spring I may go in for a realignment and sit in the car for it (I'm 210Lbs). Worth it to do it with me in the car? . I'd like a little less in the rear and more in the front.
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 03-07-2018, 02:19 AM   #5
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
I have a V6 1le and could only get -1.7 in the front.
Kairles is offline   Reply With Quote
Old 03-08-2018, 09:59 PM   #6
mbar
Drives: 2016 1SS
Just re-did mine. -1.9 one side. The other maxed at -2.1
Rear topped at 1.4 If you want to stay at positive toe.
Every car will be a little different.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
