Old 02-28-2018, 05:12 PM   #1
Joel2702zzz
Drives: My Dad's car is a '16 1SS 6MT
Anyone Got A Tune File
does anyone have a flex fuel hptuners file,
that would be greatly appreciated.
Joel2702zzz is offline   Reply With Quote
Old 02-28-2018, 05:18 PM   #2
jimmypop13
Drives: 2016 camaro ss
Efi live posted one on here along with the change log. Search it
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 02-28-2018, 05:26 PM   #3
KonigWolf
Drives: 2016 2SS A8
Correction, it was posted by Tsloper.
http://www.camaro6.com/forums/showthread.php?t=469951
Bottom of the first post.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 02-28-2018, 06:10 PM   #4
Joel2702zzz
Tried that one but it had parameters that were not available on our car in hptuners.
Old 02-28-2018, 07:00 PM   #5
jimmypop13
Thank you! I meant to say EFI Tuning which is his company.
Old 02-28-2018, 07:02 PM   #6
jimmypop13
The parameters are there if you have a 2016+ Camaro SS. If you don't see them it is because you aren't on the latest beta release of hptuners 3.7. Email hptuners support with your serial number and they will add it to your online account
Old 02-28-2018, 07:46 PM   #7
Franko07
Drives: 17 white 1LE
mine is 3.7 beta and its different aswell
his change log is awesome if i could find all the settings. Mine is a 1LE so it may have too many differences to do a compare file.
Franko07 is offline   Reply With Quote
Old 02-28-2018, 07:50 PM   #8
KonigWolf
Drives: 2016 2SS A8
Ahh, gotcha, wasn't sure how the two user names were related.
How are you using the file? Are you loading your file, then comparing it against this file?
It has everything needed in it, because I used it to setup my E85 tune.
I guess if you guys are having issues, post up your tune files, and when I get to my PC I'll take a look an see what's going on.
Old 02-28-2018, 08:14 PM   #9
jimmypop13
Hmm. I guess 2017+ looks a little different or doesn't have all the same tables unlocked yet
Old 02-28-2018, 09:46 PM   #10
Franko07
Here is my file for the 17 SS 1LE
To be Honest i think they have simplified the E85 info but dont have anything to compare with.
Old 03-01-2018, 11:40 AM   #11
KonigWolf
Drives: 2016 2SS A8
I just compared the EFI E85 tune file against the 1LE file you provided, and everything was there. The only thing I seen that was incorrect was a naming tab error, but that had been changed because of HPtuners update.
EFI Tuning LLC
Tuning Tool: HP Tuners v3.2.x
Platform: 2016 Camaro SS
File: 2016_ss_flex_fuel_baseline.hpt
Changes:
*** required ***
- modified Engine -> Fuel -> General -> Air Fuel Ratio -> Stoich AFR-> Flex Fuel AFRs
- modified Engine -> Fuel -> Flex Fuel -> General -> Enabled
- modified Engine -> Fuel -> Flex Fuel -> General -> Fuel Sensor -> Sensor
- modified Engine Diag -> DTC's -> P0178 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Engine Diag -> DTC's -> P0179 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Fuel Sys -> Diagnostics -> Flex Fuel -> Sensor Diag -> Enable
*** optional ***
- modified Engine -> Spark -> Advance -> Spark Correction -> AFR Correction -> Alcohol -> Gas table
- modified Engine -> Spark -> Advance -> Spark Correction -> IAT Spark -> Mult4 -> [1.00 1.00 0.80 0.50 0.20]
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Cranking -> enhanced for Flex Fuel
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Alcohol Adder -> timing added for Flex Fuel cold starts
When comparing the Flex fuel tune against your tune file, these are the spots that need to be edited.
Old 03-01-2018, 11:52 AM   #12
Franko07
here is a picture of what i see
Old 03-01-2018, 01:18 PM   #13
KonigWolf
Drives: 2016 2SS A8
Ahhh, I see the problem now! You're in basic mode. It's a simple fix!
Edit >> View >> Advance
Restart HPTuners.
Old 03-01-2018, 01:53 PM   #14
F1FTY
Drives: 2018 ZL1
Just to clarify, with these simple changes, the car will have Flex Fuel enabled and with the sensor installed, it'll be able to drive and run without a dyno tune?
It can't be that easy, can it?
F1FTY is offline   Reply With Quote
