![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Quick oil and filter check
Sorry for what I'm sure is a duplicate post but the search was all over the place. I know we have the sane drive train as a standard SS, but want to see what you guys are using. I plan to use Mobil 1 5W 30 and not sure about the filter. Thinking about Mobil 1 Platinum, Wix, or AC Delco filters.
Thoughts? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
I always use AC Delco filters. I normally go up to the better UPR filters
Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I am doing what the manual tells me to do. AC delco filter and Valvoline 5w40 dexos 2 for tracking.
Forgot to mention that I don't track my car. 5w 40 might still be good since I only drive the car in warm weather seasons.
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I also use the AC Delco filter with dexos2 5W-40, but I track mine. Since you don't track yours, you won't have any problem with an approved 5W-30 since the 5W-40 is really only needed for extended periods of high engine load and RPM where you're generating a lot of heat. Shouldn't see those conditions on the street unless you spend a lot of time at WOT
2017 SS 1LE.
![]() Drives: 17 SW 1LE Join Date: Jun 2017
Get a dexos 2 rated 5 or 0w40.
GM just announced they are going to Mobil1 5w40 ESP for all vettes so obviously 5w30 is not enough. |
#7 |
Thanks for the recommendations. Nothing on the 5w 40 esp for Camaros yet? Wonder Why? ESP is expensive and hard to find isn't It? My RAM ecodiesel used 5w 30 ESP until they changed to Rotella 5w 40 due to main bearing failures. That's a diesel though.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
I use European Castrol 0W40 with the OEM filter.
#9 |
They will probably go that route for Camaros too, I haven't been able to find 5w40 esp for sale anywhere online. I am not sure its available anywhere yet, the documentation I have says it wont be available through my normal oil program channels until July 1st.
#10 |
![]() Drives: 2017 1LE Join Date: Jul 2016
I've been running the Wix XP filter and performance supplement recommended Valvoline Synpower MST 5w40 for track days. Blackstone reports all have come back perfect thus far.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
#11 |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
I run this for track days as well. Daily driving - Mobil 1 5W-30 with the Dexos 1 cert.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#12 |
#13 |
![]() ![]() Drives: 2019 Shock ZL1 Join Date: Jan 2007
You should be able to run the new Corvette spec'd oil, 0w40 Dexos 2 Mobil 1, but the Corvette spec'd one appears to be GM dealers only at the moment. One of my emails about it did have Camaro listed along with Corvette, so I'm thinking the LT1 and possibly LT4 will be going to 0w40 in the future. If that is the case, then the oil will be backwards compatible, and is daily driving and track use compatible. No need to switch oil viscosity for track events.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
#14 | |
Interesting how GM uses Mobil 1 as the factory fill for Corvettes with the LT1 but not the Camaro with the LT1... Last edited by Cgocifer; 02-28-2018 at 07:43 PM. |
