Best Setup for Jacking and Lifting these Cars?
Searched the forum and read through all the threads but not sure what would be the best items to order. It will go to the dealership (Albeit my dealership with my techs that I know) and be lifted up on a 4 point, but I will also probably lift it up in my garage from time to time to take wheels off and the like.
Thinking about installing a set of Lift Pads for the times when it's picked up by a 4 point lift, and then a Jack Pad and Puck for when I lift it up myself. Now, when I lift it up at home, I'll use the Jack pad to lift it up in the spot just behind the front Lift point (As shown in Lethal's video) but then can I put jacks stands on the semi-permanent Lift Pads? They look like they're kind of rounded. We do have a drive on lift, but eventually it may go to a shop that doesn't have a drive on lift. This brings up another point, most dealers/owners/techs know very little about this but it's a very serious deal and most cars are probably lifted up once a year or more. At least my dealerships will be educated on the matter I guess. I only wish that was the case for the rest of the dealerships that have misaligned cars and bent pieces/frames with improper lifting procedures. Most techs in my experience are pretty smart, but if they aren't given the information, then they don't know better. |
![]() Drives: 2018 Camaro ZL1 Join Date: Dec 2017
Holy crap that seems a bit churched up. There are much cheaper options that work equally well.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Those look like a nice cheap option. Do you use those? Hell I could buy a set of those for all of my techs at a cheaper price than 1 set of the ZL1 Addons...But the reviews are pretty sketchy.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
![]() Drives: 2017 ZL1 A10 Join Date: Jul 2014
Race Ramps no question. I debated buying them for years and finally bought them a month or so ago. Absolutely love them. I also have the jack pads from ZL1 Add-ons but haven't needed to use them yet.
How do race ramps help with taking the weight off the wheels to get them off?
#7 |
I didn't fully read the OP before posting but nonetheless the car will already be raised in the front so less time the jack has to contact and lower chance of incorrect placement.
#8 |
Drive fast, take chances.
Drives: 69 Z/28, 85 SS Monte, 01 2500HD Join Date: Jun 2017
I use a set like the ones from the link, and a couple other different shaped pads for a lot of my vehicle work, I think they work pretty well. I also have a set of the ZL1 Addons I will be installing, in case I need to have someone else work on the car, for the reasons you mentioned.
18' ZL1 1LE, Mosaic Blk, PDR, CF Trim, CF Fuel, TM TB, CAI Elite Carbon Series
#9 | |
I had that brilliant idea once as well and the puck ended up splitting in half. This was is better suited to this purpose. |
#10 |
![]() Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10 Join Date: Feb 2017
I installed these. Way easier then laying on my side trying to line up a puck every time. https://zl1addons.com/products/jack-...nt=32532898689
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer |
#11 |
![]() Drives: 2018 ZL1 Join Date: Dec 2017
ZL1 Addons x4 or so!!!
#12 |
![]() Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
I picked up a full set from ZL1ADDONS..... with the pucks. It works best to get the 3" pads for front and smaller for the rear. (The rear pinch welds have a turn in them and the 3" will not fit). I have a 4-Post with sliding RJ3500 sliding jack on it.... worked great. (I did though add some small "side" padding on the inner channel walls to keep the pinch weld as much in the center as possible. Just used some adhesive backed corked (super thin), two layers each side.
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
#13 | |
![]() Drives: none Join Date: Nov 2012
#14 |
![]() Drives: Sold! Join Date: Nov 2017
I got the ZL1 Addons lift points for quick stuff around the garage and it makes it super easy for jacking.
I also have the Amazon special rubber pads and use them for jack stand work. |
