Old 02-27-2018, 12:41 PM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Heat stopped working -- Update: Need help regarding dealer.
2017 Camaro 1LT V6.
So I'm driving and I notice it's pretty chilly inside so I check the blower settings and they are at 80 F ... I turn up the dial to 85 and set the blower on high and it blows nothing but straight cold air. It had been running for atleast 20 minutes by that point too. I turn it all the way down and all the way up again and it got slightly warm... But felt more like upper 60's and lower 70's.
I stopped, exited the car, re-entered and restarted it and it's still blowing cold air... It is doing it both on recirculate and non recirculate... Any idea as to whats going on?
Need4Camaro is offline   Reply With Quote
Old 02-27-2018, 07:47 PM   #2
ShadySS
Drives: 2017 Hyper Blue SS
If a simple disconnecting of the Negative terminal doesn't help and nothing else you try seems to, then just take it to a dealer, this is exactly what warranty is for
Other then that I have no advice for you, hopefully some others, can chime with some tips to help.
ShadySS is offline   Reply With Quote
Old 02-27-2018, 07:51 PM   #3
glenB
Drives: Chevrolet Camaro SS
If the modes are working properly, then most likely the blend door
glenB is offline   Reply With Quote
Old 02-27-2018, 07:52 PM   #4
Liralen
Liralen's Avatar
Drives: 2013 KBM Camaro 2SS Hot Wheels
I had that happen when had my 4th gen, it was when the thermostat got stuck or the water flow to the heater/air conditioning unit got clogged up. Really sucks when it is 40-50 degrees out and you are two hours from home! Of course your car is not old enough to have the second issue...
2018 Hot Wheels SE, Convertible, V8, 2SS, M6, MRC, Nav, NPP
TPW 3/12; 1100 - 1/29; 3000 - 2/7; 4200 - 3/13 & VIN (built 3/12], delivered 4/26; mine 4/28. (aka HOT CRUSH)
Garage:
2013 HotWheels SE Camaro, Coupe, V8, 2SS, Auto, #987 (aka V8HOTTY)
2014 Z51 Stingray 3LT Corvette, M7, Coupe - Laguna Blue Metallic
2016 Harley Davidson Roadglide, Screaming Eagle
2017 50th Anniv SE Camaro, Vert, V8, 2SS, M6, NAV, NPP, #537 (aka FIFTY)
2017 Silverado High Country, full bed/crew cab, Iridescent Pearl Tricoat
2018 Silverado LTZ, short bed/crew cab, 100th Anniv, Centennial Blue (aka CENTURY)
Liralen is offline   Reply With Quote
Old 02-27-2018, 09:33 PM   #5
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
Very possible. Or a bubble in the cooling system(coolant)
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 02-28-2018, 12:30 AM   #6
Need4Camaro
I hate intermittent issues. So later today out of the blue it started working again and has been working since. I already scheduled a dealer visit, note my car has 29,900 miles and the bumper to bumper coverage ends at 30,000 miles which means anything that isn't powertrain related will no longer be covered. So I'm hoping they take a deeper look into it other than saying "Oh its working fine" and turn it away..
Old 02-28-2018, 08:22 AM   #7
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Hopefully your heat keeps on working with no need for the stealership goons to get involved.
STYLO LT1 is offline   Reply With Quote
Old 02-28-2018, 09:22 AM   #8
Need4Camaro
I'm actually sitting at the stealership right now. I made a video recording of the mileage (29,850) and did a video walk around of the car and it's condition before dropping it off right infront of the service department. The issue is after 30,000 miles, heat and A/C is no longer covered under warranty. So I am having them look at it just incase, and if for whatever reason it stops working later after 30k miles I have proof that I brought it in and had it looked over so it was technically an existing issue before the warranty expired so I should be able to get it covered.
If it turns out to be anything electronic it would be very expensive to repair it out of pocket.
Old 02-28-2018, 09:30 AM   #9
fastball
Drives: 2017 Camaro 2SS 6MT
WHAT????????? Who the heck told you that?
The whole car is covered for 3 yrs/36,000 miles!!!
fastball is offline   Reply With Quote
Old 02-28-2018, 10:10 AM   #10
ctrlz
I agree with fastball.
This problem sounds like intermittent electrical failure. Could be controlling module, actuating motor, or anything in between.
there is also the possibility of something physically obstructing a damper. Apparently they don't pay too close attention to the insulating foam when they put this system together, which is why some owners get bad fogging of the windshield from the A/C in humid weather (cold air leaks through defrost vents and cools glass, condensate forms on outside).
Old 02-28-2018, 12:02 PM   #11
fastball
And it's not even a matter of agreeing with me or not. All you have to do is open your owners manual.
A dealer that tells you your factory warranty is anything but 3/36 overall and 4/50 on the drivetrain should not be selling anything but fake Rolexes!
Old 02-28-2018, 12:19 PM   #12
Need4Camaro
My dealer told me everything is covered bumper to bumper only till 30k, service department manager even told me this. Powertrain is covered till 65k per the service departent.
Admittedly I get very seldom (and I mean literally once maybe every 6 to 8 weeks) weird electrical issues. I will be driving and out of nowhere for no reason at all EVERYTHING shuts down except the motor. No gauges, no radio or Mylink display, no climate control, turn signals, not even the interior lights.. EVERYTHING .. while the engine continues to run..then about 5 seconds later it all just seems to reboot, gauges do their startup process (going to max then 0 then report the actual readings, mylink completely reboots showing the Chevy emblem).. I have just called it off as a glitch since it doesnt happen very often and havent really addressed it.
I also get that horrible fogging of the window but I've figured out how to minimize and prevent it (using Defroster with the setting on Recirculate Air instead of outside air) and that usually works. I don't feel like having my dealer rip out my entire dash and windshield to fix it so I haven't addressed that.
I probably should read that darn manual, but anyhow if they give me flack about it I'll bring it up...if I still get flack I'm going to another dealer.
Old 02-28-2018, 01:14 PM   #13
fastball
The industry standard for most production cars from all manufacturers is 3/36, 4/50. I thought this was common knowledge?
Some premium lines have longer, and of course Kia has a 10/100,000. But the industry standard is 3/36, 4/50.
Holy cow. You need to get out of that dealer right now. If they're telling you that, no telling what else they're screwing up on your car or with you.
Old 02-28-2018, 01:28 PM   #14
ModdedSS
ModdedSS's Avatar
Drives: 2017 Camaro SS 1LE
It's a 5 year 60k miles powertrain warranty, not 4 year 50k
Show: C7 Carbon ZL1 Front Splitter/C7 Carbon ZL1 Side Skirts/Diode Dynamics LED Sidemarkers/Tinted Headlights, Fog Lights, and Rear Reflectors/20" Forgestar F14's in Bronze Burst
Go: 17" Forgestar F14s in Bronze Burst with Hoosier Drag Radials/Rotofab Intake w/ Dry Filter/EFI Flex Fuel Kit/Kooks 2" Longtubes with Offroad Connections/PRAY Performance Ported Intake Manifold/PRAY Performance Ported Throttle Body/PRAY Performance Ported Heads/PRAY Performance Tune
Suspension: Phastek Lowering Springs/BMR Toe Rods/BMR Control Arms/BMR Trailing Arms/BMR Strut Tower Brace
ModdedSS is offline   Reply With Quote
