![]() Drives: 98 Transam drag car SOLD now 17 ZL1 Join Date: Feb 2016
Upper or lower?
On having low side fuel pump, Flex fuel sensor on, ported throttle exhaust....... But was going to do a pulley.
Suggestion on which one to do, best bang for the buck as far as power and money?
Sold 780rwhp 840rwtq 98 Trans Am Current car 2017 ZL1 Camaro |
![]() Drives: 1le Join Date: Mar 2017
lower pulley will give better belt wrap but be more expensive. The upper pulley will be cheaper but more prone to belt slippage in most normal supercharged applications. id go 18% lower if it was me.
Which would be cheaper labor?
![]() Drives: 2017 ZL1 Join Date: Mar 2014
All things being equal, doesn't the lower pulley usually show a greater increase in torque production?
![]() Drives: 2017 BLACK ZL1 A10 Join Date: Jan 2018
![]() ![]() Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
There is a number of threads on this topic. Regarding belt slippage (theoretical or real), various OD % on lower, need for accessory mods (like Headers) for various applications, etc. Lot's of good info, you just have to sift through a little bit
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() |
#7 | |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
https://weaponxmotorsports.com/blogs...ng-mods-needed There are a few factors that come into play. The lower pulley being replaced reduces the rotating mass on the front of the crankshaft; however, when going to a larger diameter of rotation, this affects the MOI (moment of inertia) as you're essentially moving some mass (albeit less) further out from the vertex of the crankshaft. The upper pulley we can go all the way to a 15% increase aka 2.175", but the snout needs machined with anything less than a 9% aka 2.3" upper. We offer the snout machining, porting, and pressing a pulley on and can ship back. Our Griptec pulleys eliminate the static slip that occurs when the crank taxes the upper pulley, so "the lower is always better" thought process is gone. https://weaponxmotorsports.com/produ...-zl1-gen-6-lt4 ![]() Doing the lower, you can actually go up much further with over-driving the supercharger, but anything over a 15% really needs headers anyway to get rid of the restrictive cats which hold in heat. You can run up to a 25% lower with heads/cam/headers etc for that high 700whp range though. IW lower kit goes up to 31% lower: https://weaponxmotorsports.com/produ...-zl1-gen-6-lt4 ATI lower kit goes up to a 25% lower: https://weaponxmotorsports.com/produ...ts-v-gen-3-lt4 Belt choices for various combos: https://weaponxmotorsports.com/produ...ts-v-gen-3-lt4 |
#8 |
Thank you Ben for stepping in with the info. You're not too far, I may ship out my snout to you for an upper on my Z06.
OP, what Weapon-X said is all you need to know. :cheers: |
#9 | |
![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
Weapon-X, I really appreciate your post. They are very informative, particularly for those of us that are new to this. Keep up the good work!
#10 |
That is awesome input, I don't have headers but I do have CA delete pipes so would 18% still be to much?
#11 | |
#12 | |||
I deleted my cats when we did my ported blower, stage 2 intake, and 103mm tb and I made 660whp on E85 running the stock pulley combo; however, headers still would've really picked up more. This was just testing before we started the rear mount turbo. Quote:
#13 |
I have catback already and then these cat deletes will get rid of the last 2 other than having mufflers. have the stainless works system
#14 |
Why piece it together and have doubts...Just order a pair of Headers and connection pipes. Once you're past the Headers + Primary cats, the rest doesn't matter nearly as much, hence why running a stock cat-back is standard procedure on these cars even when highly modified. Cat-backs do essentially nothing for your engine's needs. A secondary cat delete or even a primary cat delete does not replace the job of Headers/Catless or GESI cats.
