![]() Drives: none Join Date: Mar 2017
oil change and alignment didnt go as planned
Went to dealer yesterday to get my first oil change (650miles) i know its not necessary but i wanted to use one of my two free oil changes from GM. they flat out denied it and said not until 5000 will the gm oil change be covered by them.
also went to check alignment because a friend with another 1le who i know for a fact doesnt drive the car hard (because hes terrified of it) and has completely bald tires front and rear at 5000 miles. I got this read out from them and they said they fixed a few specs but as you can see above its the specs for the FE3 suspension camaro not our FE4. needless to say they argued and argued with me saying that the specs dont change and fe3 and fe4 suspensions get the same alignment. anyone want to chime in? am I over reacting here and should just trust the "PROS"? |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Regarding the oil change, find a new dealer.
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
Agreed, new dealer for the oil change. Alignment will all depend on how you drive the car. If you are daily driving it and will never see the track, what you have above would probably be just fine.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
His question was is the FE3 and FE4 the same?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
![]() ![]() ![]() Drives: 2021 Tesla Model 3 LR Join Date: May 2016
I echo about the dealer issue with the oil change. Those two oil changes are for you to use at anytime during the two year period. Mine had no problem doing it at 1500 miles( I did pay for the difference though for Mobil 1).
The same what? Suspension components? No, they have different springs and tuned MRC. The same alignment specs? It doesn't matter, proper alignment specs are subjective.
#7 |
![]() Drives: 2017 1SS 1LE Silver Ice Metallic Join Date: Jun 2016
I got my first oil change at 500 miles, and then did my own at 1500. I'm about to get another at 3500 from the dealer. That dealer sounds like an a hole...
#8 |
![]() Drives: 2018 1SS 1LE Join Date: Aug 2017
The Dealer I used for the oil change had no problem doing it at 800 miles. I did not purchase the vehicle from them. They were still 100% happy to do the change when I wanted it.
#9 | |
just thought the alignment specs would be different for fe3 and fe4 |
#10 |
im going to try and get them to show me in writing where they say the oil change can only be done at a specific milage or time when its being done through the two first free ones
#11 |
sounds like my fear of having a shitty dealer is true . which is sad because the purchasing process was nothing more than excellent
#12 |
What do you mean with “proper alignment spec are subjective?” Sorry for the dump question.
Soleil
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
I had a similar experience with our local Toyota dealer. Wife’s van had 2000 miles and I wanted the oil changed (free coupons when purchased new). They said no their “special synthetic” yes he actually said this only requires 5K mike oil changes. Well after arguing about special oil and engine break in they changed it. I have never went back and use my own special Mobil 1 oil lol
Find a new dealer ASAP Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#14 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
