Old 02-22-2018, 11:44 AM   #1
WhiteLightening
WhiteLightening's Avatar
Drives: 2016 Camaro V6 RS, 2005 Mustang GT
ATS-V engine swap??
Is it possible to swap a ATS-V engine into a 2016 camaro? Needing some thoughts on this..I searched in web and haven't found much..
2016 Camaro RS V6, Custom Leather interior, Flowmaster American Thunder exhaust, x pipe
WhiteLightening is offline   Reply With Quote
Old 02-22-2018, 11:50 AM   #2
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
You would probably spend less money and have fewer headaches if you just upgraded to an SS.
Mister Will is offline   Reply With Quote
Old 02-22-2018, 11:56 AM   #3
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
Or buy a used ATS-V.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 02-22-2018, 12:07 PM   #4
shaffe
Drives: 21 Bronco
I am sure it's possible, but probably going to need very deep pockets
Lets keep it simple. ..
Old 02-22-2018, 12:14 PM   #5
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
Anything is possible with the application of enough money.
Buy an SS . A FAR cheaper solution.
Frank237 is offline   Reply With Quote
Old 02-22-2018, 12:39 PM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I'd rather go the other way -- swap an LT1 into an ATS-V sedan! It's a much more practical car!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 02-22-2018, 12:53 PM   #7
parish8
Drives: 17 SS a8
If you like turbos get A ss and put twins on it.
Old 02-22-2018, 01:03 PM   #8
AJL13
Drives: 2017 Camaro RS
Probably the wrong place to get an unbiased answer; this forum seems to be very anti-LF4 for some reason. That being said, yes, just upgrading to an SS is a much cheaper, less-painful alternative, unless you REALLY like F/I.
The great thing about the LF4 is that with just a tune, you'd be pushing around 500 whp. But yeah, your smarter alternatives are to A. Just upgrade to an SS or B. Just get an ATS-V if you really want the LF4.
AJL13 is offline   Reply With Quote
Old 02-22-2018, 01:14 PM   #9
edillen1
Drives: 2017 Summit White 1SS
It would literally prob be cheaper to buy an SS and put a nice twin turbo kit on an LT1.
edillen1 is offline   Reply With Quote
Old 02-22-2018, 01:31 PM   #10
shaffe
Drives: 21 Bronco
Well not just unbiased, but first you would have to find a donor ATS-V if you wanted to just pull an LF4 out of it. I would imagine the engine would still be pretty pricey. Then there is all of the computer harnesses and wiring which I am sure would be a nightmare. That's simply going to cost a lot of bucks
Old 02-22-2018, 02:03 PM   #11
doc7000
Drives: 2004 Pontiac Grand Prix
You have the 3.6L V-6 engine, so it would make no sense to buy an ATS V engine to swap when you can bolt on a twin turbo system to your 3.6L V-6 engine.
doc7000 is offline   Reply With Quote
Old 02-22-2018, 02:12 PM   #12
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
I'm shocked you're the first person to say that lol. I'm reading this thread going "he's already got a v6" just turbo it!
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
Old 02-22-2018, 02:21 PM   #13
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I opened this thread hoping to see someone had swapped an LT1 into the ATS-V!
I would own a ATS-V right now if it had the LT1 in it instead of the TT v6
Old 02-22-2018, 02:32 PM   #14
HDRDTD
Considering all the engine control modules/electronics used in our cars these days and how they all talk to each other, I think it would be a HUGE task just to get the engine to run.
