![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
How bad is your oil consumption. Specifically 1LE.
How bad is your oil consumption? I am using about 4 qts between oil changes and I have 25k miles. Specifically 1LE guys that drive hard every day and track it.
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
I didn't notice any consumption in the 4k miles and 12 track days I did with mine when I had it.
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
No noteworthy consumption with mine after 13k miles.
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Basically zero. Even after four 30 min sessions at Daytona, nothing lost i could measure. Note, you can be fooled. I swear this motor takes a while to drain back into the pan...
![]() Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC Join Date: Jan 2016
Get that thing to the dealer, sounds like you're getting an engine.
#7 |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
13k miles, 25+ days on track, zero oil consumption.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
At one time GM considered one quart of oil consumed in 1000 miles as normal.
Not sure of their current policy, this was about 15 years ago. Toyota considers one quart in 1300 miles normal, just for reference. |
#9 |
![]() Drives: SS Join Date: Sep 2016
Zero consumption.
2017 HBM 1SS 1LE w/PDR
Past: 2009 Cadillac CTS-V, 6-speed manual 2008 Corvette Jet Steam Blue, manual 2005 Cadillac CTS-V, Stealth Gray 2003 Corvette Z06, Black |
#10 |
![]() Drives: 2017 Hyper Blue SS 1LE Join Date: May 2017
Mine used a quart of the factory fill, but none since going to M1.
#11 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I run Motul X-Clean 8100 5W40. Its was one of the few Dexos 2 oils available in late 2016 when I got my car.
#12 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Apr 2013
No real consumption to report on my side either. I only have 2500 miles but I've tracked it a number of times. In my oil catch can I have just a bit that get's caught. But it hardly registers on the dip stick.
#13 |
![]() Drives: 2017 SS 1LE Garnet Red Join Date: Nov 2016
None. Something's going on with your engine.
#14 |
![]() Drives: 2017 1SS 1LE Black on Black Join Date: Feb 2017
Or last oil change they did not put in 10 quarts
