![]() Drives: 2017 2LT Join Date: May 2017
V6 LGX Exhaust Setups
Hello all. I'm thinking about adding an exhaust to my V6 RS sometime soon. I've got a pretty tight budget, however, so I've started considering my options as far as exhausts go.
I am 95% sure I want to do quad tips, I think they look much better on this car, especially because the gloss/satin diffuser. However, if my only options are to go with dual tips, then I will probably wrap my diffuser gloss black. So far, I've considered these options. Borla Atak Catback + 2nd Cat Delete - I really like the sound from this exhaust. My only negative concern is the rasp at high RPMs, which can probably be solved by an xpipe. However, I think the non-NPP Quad Tipped version is WAY too expensive, I mean, four figures for a CATBACK exhaust for a V6? Not to mention the $200 I'll need for the OEM rear diffuser? Doesn't make sense to me. Muffler Delete + Magnaflow Resonated X-Pipe - I think these sound good when the exhaust shop does them properly. It's economical too, which is another good thing. My only concerns are a) Exhaust shops seem to not know how to align tips (not a big concern though) and b) Drone. I added the Magnaflow Resonated X-Pipe because I hear that it eliminates most of the drone. However, I'm still a little concerned about some drone. As for the quad tips, I'll buy the quad tip diffuser, the wrap, and the actual tips themselves so the shop can do quad tips. I bet this can be done easily for around $500. MBRP Quad Tip + Magnaflow Resonated X-Pipe - I know MBRP just relased their dual tip, and I already can't wait for the quad tipped version. I feel like pairing this with a Resonated X-Pipe as well as the Helmholtz resonators on the MBRP will effectively eliminate drone for an economical price. However, my concern here: apparently a quad tipped version is "in the works" but that's what everyone with a dual tip version says. I'm just concerned about a long wait, or maybe it may never even come out. So, keeping those in mind, what exhaust system do y'all have on your (naturally aspirated) LGX engines? How much did you pay for yours? Can you upload a sound clip (cold start, warm start, revs)? I'm just trying to gauge my options as far as exhausts go. Thanks everyone. |
#2 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Apr 2014
Borlas are nice but theyre super pricy for what you get. Where are you hearing about drone with the MBRP? I think that one sounds bad ass. I have the flow master and love it, I think it sounds great. Ran me $400 on sale. https://youtu.be/c0F404xJoGU https://youtu.be/nLlujR-QK9g |
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Any exhaust with the Magnaflow 11386 will have very minimal drone. Muffler delete will have a little drone but it isn't bad, if you have stock cats you probably won't have any tbh. 2nd cat deletes will make it a tiny bit louder but the power is sweet so I definitely recommend that. If you guys don't have the 2.5 to 2.25 neck down that we did, you don't even need a cat back, just cut and replace what you need (i.e. cut out the 2nd cats and weld pipe in, cut out the x and weld the Magnaflow 11386 in). No need to get fancy. Function is everything.
If you're on a tight budget just stick with dual tips. Quad tips is just cash for pure appearance. And you can google comparable 2011-2017 Mustang 3.7 or any 2012+ Camaro 3.6 exhaust combinations to get a good feel. Stock will sound different because of various minor design differences but modified between the 6s is very near.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
![]() ![]() Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
So With the MBRP axle back for v6 since its pretty modular the tips just bolt on you could get quad tips for it.
Deleting 2nd cat is going to deepen your sound and give you some little burbles. However this is still emissions required so check state laws. Mysetup is pure 3" stainless downpipes into carven TR turbo style mufflers the connected to those is the v8 3" MBRP black race series catback... No mufflers no cats no resonator, I am not recommending you do this I am just showing you can do whatever you like on a budget. My entire setup with labor and parts and the custom downpipes was less then $1500 dollars. What I would recommend you do is start with a muffler delete wont cost much and if you don't like it then buy an axle back of sorts.. Deleting your resonator is where your going to develop tones of drone and rasp on a stock NA setup so I wouldnt advice removing the xpipe resonator unless your going to replace it with the magnaflow one.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
#5 | |
waddupdgriff
Drives: Supercharged 2016 2LT RS Join Date: Sep 2017
That being said, I guess my next step personally will be to buy the Magnaflow X Pipe and get someone to cut the secondaries. I’m kind of excited now lol.
2016 Chevrolet Camaro 2LT RS
Edelbrock E-Force Stage 1 Supercharger Custom tune by Overkill Motorsports AFE Momentum GT Pro Dry Cold Air Intake MBRP SS Cat Back Exhaust iROC-z Wheels Nitto NT555 G2 Tires (275 fronts, 305 rears) Last edited by dgriff14; 02-23-2018 at 02:48 AM. Reason: Forgot the Y in Dustya |
#6 | |
#7 |
3" for N/A is fine just give more room for sound to bounce and vibrate/resonate not that you cant do it but you are correct it will sound different then on a boosted car. There will be no performance difference on a N/A car between 2.5 and 3" pipe especially if your just dealing with axle back.
#8 | |
We don't have V8s though. Stock vs stock there's a 12hp difference between our engines. We could run a single 3" exhaust and gain low end power without sacrificing any top end because a single 3" pipe can support something around 340hp if I am remembering correctly.
#9 | |
However if you are going to connect at your cats which are burning excess fuels up and running at temperatures above 1200 degrees I doubt the 3" pipe is going to create enough cooling effect to slow down gasses that much. However in the end I was mainly speaking of axle back systems as far as having many more choices by just going with a v8 axle which most are 2.75" since that is stock v8 pipe size anyways.
#10 | |
waddupdgriff
Edelbrock E-Force Stage 1 Supercharger Custom tune by Overkill Motorsports AFE Momentum GT Pro Dry Cold Air Intake MBRP SS Cat Back Exhaust iROC-z Wheels Nitto NT555 G2 Tires (275 fronts, 305 rears) |
#11 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
![]() ![]() Engine is the same really auto or manual. But once you go boosted, the larger pioe size is beneficial. N/a not so much http://support.magnaflow.com/07techt...question10.asp
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
#12 |
![]() Drives: 2016 Camaro LT1 RS Black on Black Join Date: Apr 2017
I did a Borla S Type and new lower valance on my RS. Coming from an 01 Mustang with MagnaFlow Magnapacks on it I can tell you having 0 drone from the Borla is a huge plus. I'm 47 and have had loud exhaust systems on a lot of cars in my life, I always wanted a Borla and this car got it. I couldn't be happier. When I put my foot in it she lights up nice. I'm in California so limited on anything more then a cat back. Knowing what I know now, you can just trim your stock lower valance to fit the quad tips and looks good. Full new valance ordered online from your local Chevy dealer parts dept are about $250 unpainted. Go quad tip if your going to do it, it just looks to bad ass. Here is a quick video I posted on it if it helps.
https://youtu.be/i0qNxqp2TmM
NowAChevyGuy 2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br] Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now... |
#13 |
waddupdgriff
Hey DSX, I sent you a PM whenever you get a chance
