Old 02-15-2018, 08:27 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
What you can do with the right fuel system parts
Check this out guys.
Proud to be an LPE dealer.
https://www.youtube.com/watch?time_c...&v=KiCqwU0_-WQ
www.jannettyracing.com
email tedj@jannettyracing.com
Old 02-15-2018, 08:38 AM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
WOW!
On stock exhaust manifolds, no less.
Old 02-15-2018, 09:01 AM   #3
parish8
Drives: 17 SS a8
That is awesome.
I am a little confused about their hpfp. The video says they are using a 7.85mm fuel pump cam. Their pump says not to go over 6.5mm stroke. Did they make a new version of the pump with more stroke?
I tested their pump and it definitely can not handle the +32% fuel pump lobe on a comp cam.
Old 02-15-2018, 09:16 AM   #4
JANNETTYRACING
Originally Posted by parish8 View Post
That is awesome.
Yes new version the previous version was good to 1000 HP noted in the video.
Ted.
Old 02-15-2018, 11:34 AM   #5
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
This is GREAT NEWS! Keeping my eyes on this one.
Turbo_RORO is offline   Reply With Quote
Old 02-15-2018, 11:38 AM   #6
lokitwitch04
Drives: 2017 Camaro SS 2SS
What would be the price on that fuel system setup?
lokitwitch04 is offline   Reply With Quote
Old 02-15-2018, 01:29 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Retail is $6K.
https://www.lingenfelter.com/product...l#.WoXfRGdy6Uk
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 02-15-2018, 02:31 PM   #8
boostednut
Drives: Nothing cool atm
Hm I think for 6k I'd rather have an auxiliary port injection system. Might be more difficult to tune, but the ports would be cleaner. And under DD conditions, you still get all the benefits of DI.
Also would be running a standalone ecu which will have many more features, especially useful for a turbo car.
Different ways to skin a cat no doubt! Cool to see the DI only rout raising the HP ceiling though.
boostednut is offline   Reply With Quote
Old 02-15-2018, 02:31 PM   #9
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
Originally Posted by jessrayo View Post
Plus a pretty good amount in labor. Guessing in the thousands with the cam job and such. Jannetty will take care of you though!
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 02-15-2018, 02:33 PM   #10
boostednut
To be fair though it's no more or less than any other cam job. Which you'd need if you wanted to push 1400 crank regardless what fuel system you chose... Bar maybe stuffing an lt4 with oodles of nitrous or something silly. Labor is always going to come into play when you want big power I feel like.
But I do have to side with this setup not being worth the cost
Old 02-15-2018, 02:46 PM   #11
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
There's no way this would not require an auxiliary low side system as well. Add that to the cost. No mention if the GT35 cam comes with springs DOD delete stuff etc either so add all that to the cost as well. Looking at $8k+ in parts alone probably.
djfury05 is offline   Reply With Quote
Old 02-15-2018, 07:14 PM   #12
laynlo15
Drives: 2022 Lt1 A10
I've seen this kit in person. Can't say where, but its awesome and comes in its own case. Its not cheap either but if you want to make some serious hp this is the ticket.
Old 02-16-2018, 10:01 AM   #13
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Exactly what I was thinking!
Rlhay2 is offline   Reply With Quote
Old 02-16-2018, 10:21 AM   #14
jessrayo
Speed Freak
jessrayo's Avatar
No matter what you are going to have to upgrade the pistons if you want to go here. I still think if you are using a centi supeercharger or turbos the way to go is port. If you have a PD supercharger the port option really isn't there and it is nice to know that this option is available.
