Old 02-14-2018, 03:49 PM   #1
TeleZL1
TeleZL1's Avatar
Drives: 2018 ZL1
A10 bump in park upon startup...
I have noticed a couple of different times when I get in my car and start it, there is a quick "bump".
It has happened a couple of different times. Once I had pulled it into my drive to detail another car in the garage. It sat on a very slight incline for a couple hours and I did set the Ebrake. Got in it, hit the start button and BUMP.
Other time was the car was flat in the garage...got in to start it after not driving it for a few days and same thing. Its almost like its still partially in gear for a split second. There is no noise that I can tell and its not a hard bump but there is a definite little bump like someone barely tapped the rear end while parking.
I took it in to the dealership for my 1st complimentary oil change and asked them about it....they deemed it was probably the adaptive learning and its still learning how I drive and blah blah....
I'm not buying it. I asked them "So it doesn't know its in park?!"
Anyways, I didn't expect much from the service writers but I know its not normal.
Anyone else experienced this?
TeleZL1 is offline   Reply With Quote
Old 02-14-2018, 04:19 PM   #2
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
I have noticed this a few times as well.
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 02-14-2018, 04:31 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Electric parking brake? Is it the brakes? Or do you think it's trans related?
Sometimes after I park my performance cars, the first time I move them, they jerk, and I think it's the brakes that stick to the rotors if left wet. After the car moves an inch it's fine.
Old 02-14-2018, 04:53 PM   #4
Homey Da Clown
Drives: 2017 ZL1 A10 Vert
A10 Bump
Mine does it too. I have never used the parking brake.
Homey Da Clown is offline   Reply With Quote
Old 02-14-2018, 05:37 PM   #5
djfury05
djfury05's Avatar
Mine does it too, no parking brake. Happens randomly no trend discovered.
djfury05 is offline   Reply With Quote
Old 02-14-2018, 08:05 PM   #6
Busted43
Busted43's Avatar
Drives: 2018 zl1,A10,16 GLC300
Haven’t noticed it on mine as of yet.
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq.
Busted43 is offline   Reply With Quote
Old 02-14-2018, 08:11 PM   #7
TeleZL1
TeleZL1's Avatar
Drives: 2018 ZL1
Definitely NOT the brakes.
It’s a very quick jerk/bump from the drivetrain and it is random.
Glad it’s not just me but I hope it’s not a symptom of a larger long term issue.
Old 02-14-2018, 08:13 PM   #8
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Lil over 2,000 miles. I’ve never had that happen on mine.
ninetres is offline   Reply With Quote
Old 02-14-2018, 08:36 PM   #9
6spdzl1
Drives: 2017 Camaro ZL1
I don't have the 10 spd in the Zl1 but do have the Ford version in my F150. Does the same thing every so often.
2017 ZL1 Coupe 6spd
Garnet Red Tintcoat
2018 Corvette C7 Auto
Black Rose Mettalic (Wife's)
6spdzl1 is offline   Reply With Quote
Old 02-15-2018, 06:36 AM   #10
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Just over 2K on mine, never experienced this either.
I use the parking brake about 50% of the time and turn it on before I turn off the car.
Old 02-15-2018, 07:00 AM   #11
Jmueller
Drives: 2017 ZL1 A10 Nightfall Gray
Hmm. I have over 6500 miles and I have never experienced this on my A10.
Jmueller is offline   Reply With Quote
Old 02-15-2018, 07:38 AM   #12
thompstl1
thompstl1's Avatar
Drives: 2017 A10 ZL1
Mine does this too on occasion. To me, it feels like the drive clutches in the transmission engage momentarily, even though it's in park. Feels like it is slightly in gear, but in park at the same time. I've noticed my car moves just a bit when I feel this.
Hasn't gotten any worse and only happens sporadically.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
thompstl1 is offline   Reply With Quote
Old 02-15-2018, 08:32 AM   #13
jasonfichter
jasonfichter's Avatar
I was told that this can sometimes happen overnight when the fluid has time to drain back into the bottom of the transmission. During initial startup the clutches momentarily catch because there is no fluid on them. Once fluid is circulating the clutches slip as they should.
This is just what I have been told, sounds like that could be the case.
2017 Camaro ZL1 Coupe Black |A10|PDR|NAV|
jasonfichter is offline   Reply With Quote
Old 02-15-2018, 09:33 AM   #14
thompstl1
thompstl1's Avatar
That explanation sounds exactly like what I'm feeling when the transmission "bumps". To support that theory, I've noticed when the car sits for long periods of time it's slow to "grab" going into reverse... waiting for the transmission fluid to be pumped from the pan into the torque converter and transmission.
Actually my Ford truck (F-150 with 6 speed auto) does exactly the same thing
