![]() ![]() ![]() ![]() Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
Best chip correction brands?
I have a few chips, nothing too bad. I want to get them corrected. I feel I could do it myself.
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Dr. Color Chip
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
![]() Drives: 16 ngm ss Join Date: Jan 2017
I thought about them. Does it actually work that good? Is it that simple? Will it work on a light scratch?
Drippin' Wet Auto Detail
I've also used Dr. Color Chip on my MSB camaro. Its not perfect, but it is very simple to use and it will better than leaving the chips alone.
![]() Drives: 2LT RS Yellow Convertible Join Date: Aug 2016
Dr Color Ship. I had a chip on my A pillar and used Dr Color Chip. I applied multiple layers over time. I showed it to a professional and he said, it's a pretty damn good job. If you don't know about the chip you don't see it.
Gold Rush
#7 |
![]() ![]() Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
I used Dr. Color chip and didn't like the way it turned out. I just ordered some from paintscratch.com
I will see how this one does. I think the issue was probably user error but decided to give a different company a try. I did like that the kit from paintscratch came with a clear as well.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
#8 | |
Dr. Color chip is basically an all in one. It does not come with clear because it is built into the product/activator. It does take a little getting used to but once you get good at it you can repair small chips almost perfectly with 1/10th the effort of the old fashioned method. |
#9 | |
#10 |
![]() Drives: 2016 Join Date: May 2017
I’ve used dr. Colorchip with some success too. You just have to follow the instructions and be prepared to patiently do multiple layers to get the desired build up on the paint.
#11 |
You are the second one to mention multiple layers and I am confused. You smear the special paint, let it set, then wipe off the excess slowly with the blending solution. If done correctly this should fill in the chip completely in one go.
#12 | |
Retired from Car mfrs....
Once you get on the amount of coats that you feel covers it both in color and depth, you can wait 30 to 45 days and come back with stage one and stage two polish to get it to blend in perfectly. |
#13 | |
#14 |
Dr color chip is much, much thinner than standard touch up paint. It’s what it enables it to spread with a “smear” technique as a Opposed to standard touch up paint. Also colorchip has clear mixed in it, that’s facilitating the one step procedure.
