![]() Drives: 2016 Camaro 2SS Join Date: Sep 2016
Just pulled the trigger on a Whipple
After doing some research I have decided to pull the trigger on a Whipple. I just ordered it today so it should be here in a month. Once it is installed I am going to have Matt from GPtuning tune it for my mods. I am kind of bummed I won't be able to run e85 anymore (without updating fuel system.) I have been told a meth kit would be equivalent but I do not know anything about that. Can someone chime in please? It's my daily driver btw.
#2 | |
Drives: Compound Boost 17' ZL1 (shop car) Join Date: Jan 2017
#3 | |
![]() Drives: 2018 ZL1 M6 Join Date: Dec 2017
#4 | |
Easier to find and fix a problem on the bench and during install, then after driving it. I think most of the guys here, who installed SC'ers, have encountered just about all the potential problems. But of course keep us posted on your install and any problems you face. |
I believe GPtuning is in Hayward. I haven’t setup an appointment with Matt yet so I don’t know the exact physical address. From what I hear, he knows his stuff. Bought the whipple from TPS Motorsports in San Jose. Valaya racing in SJ will be doing the install.
#6 | |
#7 |
![]() Drives: . Join Date: Jan 2017
Good luck with your build, and congrats.
#8 |
![]() Drives: 2017 Summit White 2SS Join Date: Jan 2017
As others have noted, let us know how the install goes. have heard from a few that matt does good woork, ive been looking for a good shop close by
Follow me on IG: @lip_stick.ss
#9 |
Update: I am going to be doing the LT4 fuel system upgrade as well. Matt from GP tuning can’t touch the car till May and I can’t wait that long so I am thinking about driving to Turlock and having Josh at Starkweather do the install/tune. I am waiting to hear back from him on a quote for the total cost of install/tune. Should know more tomorrow.
#10 | |
![]() Drives: 2011 Porsche Spyder Join Date: Sep 2011
Thanks, pcw |
#11 |
My understanding is that the stock fuel system on the Camaro SS will support the addition of a supercharger. However, if you decide you want to run e85 or a different pully setup for more power down the road, you are going to need more fuel. By using the high pressure fuel pump, injectors and in tank pump the ZL1 uses (LT4) you are able to push it a little further. I am told that you still can't run full e85 until you do a cam swap which costs like $7k but you can run e60 which will give you plenty more power. Again, I am no expert. I am just going off what I have been told from reputable sources on this site.
#12 | |
#13 | |
I bite my tongue sometime. After building, modifying and driving gasoline engines (cars and bikes) PPL don't understand "Top end is only as good as the bottom end". I see some have been lucky, some not. I spun a HD motor to 9,000 RPM making power........for a couple times. Build an LT4 top end (stock cam/3 lobe, stock pistons...etc) Roll the dice! My car runs great....It is "SAFE" (under 600HP, 10lbs boost) |
#14 |
Thanks for the info, my stage 2 STI factory fuel pump was choking at 5k rpm added a Walbro HPFP and it ran like a Rolex😁.... Thanks again
pcw |
