Old 02-13-2018, 04:57 PM   #1
thebighar
Drives: 2018 1LT RS V6 Nightfall Grey
1500 mile break in ?????? Really
Was 500 on my 2010. This seems absolutely ridiculous to me. Is anybody following religiously to 1500. Also got an oil change on my last after 1500 miles, is that recommended still.
thebighar is offline   Reply With Quote
Old 02-13-2018, 05:10 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
It's up to you. GM does not recommend any break-in oil change, but I gotta tell you, the first oil that you drain at 1500 or 2000 miles or whatever is cloudy with metal dust.
As for taking it easy for 1500 miles, it's mostly about breaking in the gear wear surfaces. I would't DREAM of WOT before break-in is completed. But then, I'm an adult.
Old 02-13-2018, 07:44 PM   #3
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Not religiously, but I'm not beating on it either. This past weekend on the highway was the hardest I drove it and it was for a very short while. Still got about 700miles to go
I'm a nut about oil changes, so yeah, it's going in at around 1500 for its first with 5k changes (full synth) after that.
torqueaddict is offline   Reply With Quote
Old 02-13-2018, 08:28 PM   #4
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
I didn’t follow it religiously. I probably hit 5000-5500 rpm a few times before 1500miles. I did take it easy for about 500 miles.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 02-13-2018, 08:39 PM   #5
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
I definitely took it “easier” than normal the first 1500 miles. Did a few WOT pulls from 2-5krpms and let off quickly to create max vacuum to set the rings the first drive out after purchase (even though this is likely done at the factory). Then did all city easy driving varying load and RPMs the first 500 miles. Changed oil. Took it fairly easy after that until 1500 miles. Changed oil again. Now I rarely drive it without at least one WOT pull!
ninetres is offline   Reply With Quote
Old 02-13-2018, 08:44 PM   #6
DirectTo
DirectTo's Avatar
Drives: Sold!
I blew a shift and probably hit 6000 RPM during my test drive. Of course it’s a little less concerning with an OHC engine.
Definitely change the oil early.
DirectTo is offline   Reply With Quote
Old 02-13-2018, 09:36 PM   #7
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Just change the oil before you start romping on it. I'd baby it for the first 500, change the oil, then go ham.
soloknight6 is offline   Reply With Quote
Old 02-13-2018, 10:05 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I did what they told me. Didn't hurt anything, and I still had a good time. In the meantime, if anything DID go wrong...I can say I followed their instructions. It didn't so...all's well that ends well. Remember, the break-in is just as important for non-engine components...
The engines are not broken in at the engine plant like some think...and interestingly, the Tonawanda Engine Plant (folks that make our LT1s, and LT4s) had an engine-building display at the auto show in town; they explained the reddish coating on the rod bearing inserts was there to break in the journal-to-rod bearing point. That stuff's gotta go somewhere...
On all new cars I buy, I change the oil at 500 miles...then again at 1500.
Everyone seems to have their own methods and opinions, though.
Old 02-13-2018, 10:33 PM   #9
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Here is the consensus as far as I can tell. The ring seating is done at the factory and there's nothing you can do to change that. You can't make the rings seat better by doing acceleration/deceleration cycles. They already did that. The rings are seated. Beyond that, you are basically taking it easy while the parts break in. A few hundred miles, should be good. There are mechanics on here that have said the 1500 mile break in is too long, and from what I've seen, a 500 mile break in period is sufficient, but you do have to vary the RPMs. 500 highway miles in 8th gear at 1000rpm may not be an adequate break-in. Perhaps this is why Chevy recommends 1500?
protovack is offline   Reply With Quote
Old 02-13-2018, 10:39 PM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Bought mine as a CPO with 900 miles. Took it easy on the 200 mile ride home, after that is was 6-8 0-60 passes on a industrial back road. Lol
There is no need to wait 1500 miles to break in a engine. As the poster above mentioned, the rings are already seated from the factory. Log 500 miles, change oil, and let it eat!
Old 02-13-2018, 10:48 PM   #11
L99BEN
L99BEN's Avatar
Drives: 2023 BMW M4 Competition
This is likely how it is for most if not all newer cars. One thing that seems to be universal is to take it extra easy the first 100 miles or so(no sudden starts, extended redline, hard on the brakes..) and to vary your rpm when cruising not using cruise control. Unfortunately dealer lot test driven cars are likely driven pretty hard during the first 100 miles...
I bought my 2SS used with 1100 miles so what was done was done prior.
Anyway, if something goes wrong, that's what warranty is for.
If you properly maintain, don't run hard when cold or abuse your cars, they should last a long time regardless of the break in.
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy)
2022 BMW X3m40i
Past:
2022 Tesla S Plaid
2020 Shelby GT500 sold
2019 Hellcat Redeye-traded for new GT500
2019 ZL1 A10 - sold (meh)
2019 Tesla M3P
2016 Hellcat Challenger - A8 sold but never forgotten
2016 Camaro 2SS M6
2014 Mustang GT A6
2012 Mustang GT M6 "brembo" 3.73/FBO
2012 Camaro SS L99 (Wife's)
- slow
L99BEN is offline   Reply With Quote
Old 02-14-2018, 12:38 AM   #12
Ranch41
Drives: 2011 Z06 Carbon & 2018 Camaro ZL1
When I test drove a ZL1 A10, the sales guy said to romp on it and I suspect that is common practice so most cars with some miles are probably driven hard already. I suspect that with the high HP cars nowadays, the mfg suggested 1500 mile breakin period is probably as much to get the driver accustomed to the power and handling of the car as it is to breakin the engine and other systems.
I am a naturally gifted driver so I’m going WOT after the first couple hundred miles!
Ranch41 is offline   Reply With Quote
Old 02-14-2018, 07:21 AM   #13
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado C10
St. Catherines in Canada builds our Camaro LT1s. Only the LT1s in Vettes come from Tonawanda. I found this out later. As for break in it's up to the owner. I impatiently waited 24 years to get my 1st SS Camaro, I wanted one since I was 17, and could finally buy one in my 40s, so yeah I followed break in. I also did first oil change at 500 mi, not 1500. And I still change every 3-4K, I don't care what the computer sensor says.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB.
sschons74 is offline   Reply With Quote
Old 02-14-2018, 07:39 AM   #14
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Did the 1500 mile on mine took about 7 month to get to that point but I did as GM requested.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
