Old 02-13-2018, 12:09 PM   #1
Eddie-v
Drives: NGM ZL1 1LE
ZL1 and ZL1 1LE race ramp questions
Anyone have experience with zl1 1le and race ramps? Looking to pick up a set and am curious if the 67 XT versions will work with no front splitter scrape - or would I need to go to the 72" ramps? A few other questions: 1 piece or 2 piece version? How many wheel chocks should be used 2 or 4?
Thanks
Eddie-v is offline   Reply With Quote
Old 02-13-2018, 12:37 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
There are some posts about Race Ramps in this section, and the 67 inch version will work. The 2 piece version allows you to remove the rear portion of the ramp for easier under car access. I'd think 2 chocks would work, since the car is lifted in the front or rear while on the ramps.
Old 02-14-2018, 02:15 PM   #3
blk04sr
Drives: N/A
I thought that I saw the people saying the 56" race ramps clears the ZL1 but its close. I want to get a set to do oil changes.
blk04sr is offline   Reply With Quote
Old 02-14-2018, 02:22 PM   #4
ReefBlueCoupe
ReefBlueCoupe's Avatar
Drives: A few of each
56" clears on my 18 ZL1 by about 1/2", maybe a little less.
'18 MBM ZL1 1LE
ReefBlueCoupe is offline   Reply With Quote
Old 02-14-2018, 02:25 PM   #5
blk04sr
Drives: N/A
Thats what I though, even if it didnt I guess you can add a 2x6 in front to so its stepped a little bit.
Really I hope the 56" race ramp clears my other car...ha TBD I guess.
Old 02-14-2018, 08:31 PM   #6
WyGuy
Drives: 2017 ZL1 M6
I have the 56” ramps, the rubber air deflectors just barely rub on the ramps (non-1lE ZL1).
WyGuy is offline   Reply With Quote
Old 02-14-2018, 08:33 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Thank you for posting this thread, and those that have replied...I need to get a set myself this summer...and all of your input is priceless!
Old 02-15-2018, 07:37 AM   #8
babigguy
babigguy's Avatar
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto
The longer they are the better the angle and less chance of scraping i have the 67 and they don't hit. but from above looks like 56 will work also
babigguy is offline   Reply With Quote
Old 02-15-2018, 07:49 PM   #9
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
I use the 4" full car length ramps
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
Old 02-15-2018, 08:57 PM   #10
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Do these give enough clearance to get under the car to change oil?
Cgocifer is offline   Reply With Quote
Old 02-15-2018, 09:28 PM   #11
Blue17CamaroZL1
650HP soon to come
I'm on the bigger side so i wouldn't be able to fit but someone smaller than me might be able to.
2017 Camaro ZL1
Hyper Blue Metallic
Old 02-16-2018, 09:06 AM   #12
ReefBlueCoupe
Anyone with the 56" Race Ramps back up on to them to say service the rear diff? If so, did the front end clear the ground? I can try it, but haven't yet.
'18 MBM ZL1 1LE
Old 02-16-2018, 09:32 AM   #13
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
For changing oil I use the Race ramp wheel cribs and chock the rear tires.
I was lucky enough to find these at a local car swap.
To lift the car I use the ZL1 addons universal Jackpads
This works great for all my cars and much easier to store and move around.
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 02-16-2018, 08:21 PM   #14
Cgocifer
Cgocifer's Avatar
Hmmmm. So, you jack the car and put the wheel cribs uner, then jack thebotherbside and do the same? Why not just use the ramps?
I have the zl1 add-ons jack pads installed.
