Old 02-08-2018, 09:14 PM   #1
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
Let’s push to get aftermarket ring & pinion gears
It might not do anything, however, I just sent an email to Richmond Gear and Motive Gear, asking about the possibility of future aftermarket gears for these cars. If you are interested in shorter gears as I am, please send each of them an email asking for them. Like I said, it may do nothing, but the squeaky wheel gets the grease.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 02-08-2018, 09:26 PM   #2
parish8
Drives: 17 SS a8
does the ring gear bolt on to the carrier? someone gave me the impression the ring gear is permanently attached to the carrier, maybe friction welded like a driveshaft yolk. does anyone know if this is true?
Old 02-08-2018, 09:53 PM   #3
My87z28
I’ve read from one of the guys on here that it is welded for the SS diffs. If it is then it would likey have to be a R&P and carrier combo kit. Even so, it wouldn’t be too hard for Richmond or Motive to pair up with Eaton to produce a kit. It would likely be upwards of $1200-1400, but I think it would be worth it. Especially for the M6 guys.
Old 02-08-2018, 10:20 PM   #4
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
In 4 a 3.9...
HyperspaceTurd is offline   Reply With Quote
Old 02-08-2018, 10:40 PM   #5
asthmamax11
asthmamax11's Avatar
A set of 4.10's would be great for my set up
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 02-08-2018, 11:31 PM   #6
james duperre
james duperre's Avatar
Drives: 2018 Camaro 1SS
there was a thread a while back about this. a bunch of u had sent emails
james duperre is offline   Reply With Quote
Old 02-09-2018, 11:33 AM   #7
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
The ring gear is welded to the differential in the SS. (and every other non-eLSD Alpha-platform car)
I'm working with OS Giken to try and get a (legit, tunable) LSD made that'll accept a bolt-on R&P and fit inside the stock carrier so people can change final drives.
I've got an active discussion with Linamar (the company that makes the factory GM assembly) to possibly supply us OEM R&P sets, but we're still pretty far away from having an easy bolt-together solution.
If you guys are interested in this, I highly recommend you email OS Giken and tell them you are interested. (sales@osgikenusa.com) This is not an easy thing to bring together since it is going to require some coordination with gear makers, they need to see that the effort is worth it.
rotis is offline   Reply With Quote
Old 02-09-2018, 02:18 PM   #8
My87z28
Just sent them an email.
It’s wild that GM engineers decided to weld the ring gear to the carrier. I’ve never heard of this being done in any other car from the factory. I still wouldn’t think it would be all that challenging to design and produce a bolt on R&P with carrier package for these cars.
Old 02-10-2018, 01:28 AM   #9
KonigWolf
Drives: 2016 2SS A8
That's a bummer to hear that the ring gear is welding on. Anyone happen to have any pictures of this? At they just tack/spot welds or are they full on welds to the point they had to balance it?
I'm also curious if the R&P is the same between the LSD and eLSD units.
I wouldn't mind swapping in a 2.85, it's not much of a gain over the 2.77, but it all helps, an being OEM it should be cheap.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 02-10-2018, 12:05 PM   #10
Srt-cuatro
Drives: 2017 SS 1LE
I have a SS 1LE and I would be interested in 3.91. Does anyone know the differences between the R&P in the SS and the one in the 1LE?
Srt-cuatro is offline   Reply With Quote
Old 02-11-2018, 11:51 AM   #11
oldman
Drives: SS 6 speed of course
I don't think welding is an issue, most guys were going to do a torssen or trutrac anyway for the physical diff. So it ain't a bug it is a feature.
Old 02-11-2018, 12:44 PM   #12
rotis
rotis's Avatar
The welding is an issue because we have a chicken-and-egg situation. Nobody makes gears because you can't bolt them to the stock assembly. Nobody makes a diff because there are no gears to bolt to it. We need to solve both at once, that's what I'm trying to do with OS Giken, Linamar, and US Gear.
The eLSD assembly is completely different, made by a different supplier for GM.
We aren't the only ones to have welded ring gears, newer BMWs have the same problem- http://autotech.com/bmw-install-kit-...ears-215k.html
Old 02-13-2018, 01:21 AM   #13
Mountain
Mountain's Avatar
I would love to have a True Track or Torsen... Being able to go to a 3:91 would be an added bonus.
Old 02-13-2018, 01:29 AM   #14
Mountain
Mountain's Avatar
Makes you wonder what GM’s plan is for service when the clutches wear out on these stock limited slips. To my knowledge, there is no service parts for the clutches and the certainly is no service procedure to change them.
