Old 02-06-2018, 06:52 PM   #1
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Fulltime MS109
I have a chance to get my hands on a 55 gal for a price I find attractive... I was wondering what the drawback of running MS109 full time would be? I hear since it is a heavier fuel it is easier to build and keep up pressure with VS e85. Is this true? Am i completely off here? thanks in advance.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol //
(purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills)
// 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap //
exxit is offline   Reply With Quote
Old 02-06-2018, 08:23 PM   #2
Snowblind
Snowblind's Avatar
MS 109 (105 octane) is prob one of the best gas based fuels that you can buy, you are going to need timing and maybe fuel adjustments on your current tune to realize the gain or you will most likely lose power. Drawback is price..bigtime. I don't know your specs but I would think that an e40 mix will be much cheaper on the wallet and it may make even more power than the MS. My .02
Old 02-07-2018, 02:05 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Really good fuel, one of my favorites.
Although you would need less of it than E-fuels, you will need more of it than gasoline.
E-10 has a stoich value of 14.1
MS109 has a Stoich value of 13.4 this will put more demand on your fuel system that is already maxed out on gasoline.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 02-07-2018, 02:26 PM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I've used MS 109 but was not impressed. I don't have cats so I don't need unleaded fuel. If you still have cats it is supposed to be the best unleaded. I run c16 or just good old aviation fuel. They both make more power for me than MS109.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 02-07-2018, 07:12 PM   #5
laynlo15
Drives: 2022 Lt1 A10
I went through about 50 gallons of Vp MS 109 and I am impressed, even when I wasn't running a little meth/water it really allows you to run a lot of timing and it is expensive. I was pay 70 bucks for 5 gallons, it went up to 75 so I bought a 55 gallon drum for 700 so I saved some bucks doing that. Once I start racing I won't really drive it much on the street so after a while it will be straight 109 in the tank which is as stated above 105 octane, love the smell.
Old 02-08-2018, 03:40 AM   #6
boostednut
Drives: Nothing cool atm
One of the benefits from e85 from what I understand is it's a bit more friendly in terms of power; you can be a bit rich or a bit lean and the power being made is roughly the same. Same with timing. Just generally a wider window for near maximum power.
At least that's what I've gathered over the years.
The downside is you'll get water blow by in your oil, and you need to watch out for it sitting in your tank or in storage.
I think for the cost ethanol simply can't be beat. But with the DI pump limitations... a bit more complex of an issue.
boostednut is offline   Reply With Quote
Old 02-08-2018, 04:43 AM   #7
laynlo15
I still only run 93 on the street, 109 at the track. Couldn't afford to run it at 13 bucks a gallon on the street
