Old 02-05-2018, 08:31 PM   #1
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
Check your axle nuts.
Another pubic service announcement from ole shithead.
Got 5k on my car, spirited, you might say. Passenger rear axle nut was 15 degrees loose from the torque mark. No big deal if you can torque it down, but keep an eye on it, these things ain't staked.
*the more you know...*
HyperspaceTurd is offline   Reply With Quote
Old 02-05-2018, 10:04 PM   #2
red6.2
Drives: 2010 camaro
Did you hear a clicking sound. I think my came loose and i took my canaro to the dealer but they didnt solve the noise. Did you just retorque the axle nut or replace it?
red6.2 is offline   Reply With Quote
Old 02-06-2018, 09:28 AM   #3
HyperspaceTurd
No noise, no weirdness or indication anything was wrong. Just noticed it doing a routine inspection.
We just re-torqued it to around 250 ft-lbs and put a new torque mark on it.
Old 02-06-2018, 11:08 AM   #4
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Which axle nuts are you referring to?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 02-06-2018, 12:18 PM   #5
HyperspaceTurd
The big fat 36mm nut that keeps your axle and hub um, on.
Not to be confused with lug nuts, jam nuts, or deez nuts.
Old 02-06-2018, 12:40 PM   #6
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
I needed a laugh and most respectfully appreciate the humor used...
driven2exceSS is offline   Reply With Quote
Old 02-06-2018, 06:21 PM   #7
vtirocz
vtirocz's Avatar
Thanks! When I initially read your post I was thinking of these bolts: http://www.camaro6.com/forums/showthread.php?t=505246
Old 01-24-2019, 12:40 PM   #8
16WhiteSS
Drives: 2016 Camaro 2SS 6spd
I checked mine. The nuts are staked, but the drivers side was backed off almost 1/4 turn from the factory mark. I didn't check the passenger side cause I figured I would just take it in and have service check and tighten both sides. I called two local dealers and they both gave me a "what are we supposed to do" attitude.
16WhiteSS is offline   Reply With Quote
Old 01-24-2019, 01:35 PM   #9
tom's2005gto
Drives: 2016 2SS A8 Convertible
I bought my car (used) 16 in August, it had 14,800 miles on it. I pulled the rear wheels off to check something else, and found the right rear nut backing off by several turns. I torqued it and staked it. The left wasn't loose, but I staked it as well.
tom's2005gto is offline   Reply With Quote
Old 01-24-2019, 02:29 PM   #10
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
BAHAHA!
I needed a laugh today, Thanks!
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 03-24-2020, 11:01 PM   #11
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
old thread but the 17 gm shop manual calls for 180lbft for the new style nut. but the manual is f ed up because it starts talking about thread locker after putting the nut on then goes right into the inner bolts.
Old 04-03-2020, 02:14 PM   #12
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
What is the proper torque for these nuts? I have a 2020 2SS (not a 1LE).
Also, is there a hole in the axle that a cotter pin can be placed as the nut is crowned?
My passenger side one appears to have backed off 5-10° from the torque mark...
Old 04-03-2020, 10:39 PM   #13
JCunningham
Drives: 2017 2SS M6
there is no cotter pin. if yours backed off you can take it back to the dealer to have them replace and properly torque a new nut under warranty. the nut has to be replaced. If you decide to do it yourself I can get the part number and torque spec for you. I just dont have time to search for it now in the shop manual. The nut is not expensive and easily done yourself.
Old 04-03-2020, 10:41 PM   #14
2SS Capt
2SS Capt's Avatar
Can I not just tighten the existing nut? It is only backed off a few degrees...
