Old 02-02-2018, 07:25 AM   #1
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Cigarette lighter voltage
Does anyone know the Cigarette lighter voltage on a 2018 1lt Camaro?
I wanted to use one of those plugin tire inflators.
I suppose it's 12 volts but can't find nothing in the owners manual or google.
Thanks
NYJets12 is offline   Reply With Quote
Old 02-02-2018, 07:38 AM   #2
JeromeS13
Drives: 2017 1SS/1LE
12 volts DC
Old 02-02-2018, 09:42 AM   #3
ctrlz
I suppose it's 12 volts...
Typically these get unregulated voltage. so with the car running you will get more like 14 volts. Usually the small compressors are designed with this in mind, and will move more air when plugged in with the car running.
Old 02-02-2018, 09:44 AM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Yup, compressor runs much faster with car running......
Old 02-02-2018, 11:27 AM   #5
GPz1100
Drives: 97 Z28 6MT, '12 G37 6MT
Keep in mind most cig lighters have an amperage limit. I think the cig fuse is typically 10amp or 15 depending on the vehicle. Also, thinner wires are used so I wouldn't want to be running at the limit for extended periods of time. Just checked the owner's manual, "power outlets", says its rated for upto 15 amps.
I have this pump https://www.amazon.com/VIAIR-85P-Por.../dp/B0036E9VB6 which is rated at 15A. I'm comfortable using that for emergency use, but in a garage use a compressor. Before I got the compressor I used an old car battery to power such accessories.
GPz1100 is offline   Reply With Quote
Old 02-02-2018, 05:27 PM   #6
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
I have VIAIR 85P in all my cars also...
I also recommend getting one of these and hookup directly to the battery terminals so you don't blow your cig lighter fuse. I've done it in one of my car. Luckily I know what had happened and I had plenty of fuses on hand.
https://www.amazon.com/NOCO-GC017-Ad...MEQG9QK56FAAJF
Or you can just get the model that hook up directly to the battery terminals and not use the cig lighter.
https://www.amazon.com/Viair-00087-8...SHMCA7SYP4JHE2
I`m Batman is offline   Reply With Quote
Old 02-02-2018, 05:35 PM   #7
GPz1100
That's a nifty accessory. The direct to battery is more versatile I think.
Ordered a cabin airfilter from amz for a different car with 2 day shipping. It was supposed to be here tuesday. After much bitching they put in a replacement order for next day delivery and a $5 courtesy credit on future purchases. Twice now in 3 weeks I had orders delivered by AMZ shipping get stuck in out for delivery status but never actually delivered.
Edit:
It worth noting, the compressor above is rated at 15amps at 13.8V according to their tech support. Manual says to run it with the vehicle on. If run with the vehicle off then the unit will likely draw more than 15 amps and possibly blow the cig lighter fuse (15amp). For best results, connect directly to the battery in some manner. If just topping off a few psi, I see no reason to run the car, otherwise if it'll be run for an extended period, there is a chance of running the battery down if the battery is not in good shape.
Old 02-03-2018, 09:12 AM   #8
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Yep I've got a 2 outlet splitter with some USB charge ports plugged into mine. The main plug has a digital voltmeter on it. I've seen 14.4V on it when the system is charging. Never seen it drop below 12V even with the car off.
Old 02-03-2018, 09:24 AM   #9
NYJets12
NYJets12's Avatar
Maybe your mailman is taking your stuff? Out for delivery but never getting it.
Old 02-03-2018, 09:29 AM   #10
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I use this in my power socket on the Console. It is plenty strong, does not blow the fuse and you never have to fill, check and then fill more, as you set the pressure and it fills fast and auto shuts off when the setting is reached.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 02-03-2018, 09:59 AM   #11
GPz1100
You mean amazon courier. These packages are shipped using amazon's own delivery service. I don't know what's going on but the service has been very unreliable. These packages don't show a delivery scan.
Old 02-03-2018, 12:40 PM   #12
NYJets12
NYJets12's Avatar
This is the one I got actually my sisters for you for me xmas present,
Digital Tire Inflator ,AUTOWN Portable Air Compressor Pump - 12V DC Tire Pump, Auto Shut Off
It's looks exactly the same as yours but a different name.
Works great and fast not even 1 minute per tire (5 lb per tire)
Old 02-03-2018, 04:50 PM   #13
GroundhogSS
GroundhogSS's Avatar
I got one of these from JEGS on sale:
http://www.jegs.com/i/JEGS-Performan...81042/10002/-1
It's 20 amps so you cant plug it in to the lighter socket but they include an adapter to clip on to the battery or under-the-hood terminals.
Richard
Delivered: 08/15/2016
#TeamBeckyD
