Old 01-31-2018, 10:07 AM   #1
Tim202
Drives: 2018 ZL1 1LE
Shushing The Beast
At my local auto-x venue there is a sound limit (93Db @ 50ft). I have now blown sound for the second time. Keeping the exhaust stock, what are ways to deaden the sound? I'm not looking to drill into the pipes or scratch the holy hell out of them. I'm over by 1.X Db so it doesn't need to be much....Oh and lifting isn't an option either.
Tim202 is offline   Reply With Quote
Old 01-31-2018, 10:43 AM   #2
checkeredflag
TPW 4-11
checkeredflag's Avatar
Drives: 2016 Camaro 2SS Conv. MRC M6 Npp
can't you put it in stealth mode (tour) ?
Norm
checkeredflag is offline   Reply With Quote
Old 01-31-2018, 11:01 AM   #3
ctrlz
For a temporary reduction in sound, I think you might want to try packing the exhaust tips with something like steel wool. To hold the wool in place, you could drill two picture frame spring clips and hold them together with a screw to make a cross. You can cut this springy steel to size. Push the cross into the exhaust tip to keep the packing from flying out under pressure. You should be able to easily twist and destroy the cross assembly to remove the packing once you don't need it. Maybe some long reach needle nose pliers would help. I imagine it will not take much steel wool to reduce by 1 dB. Just brainstorming here. Never tried this.
Old 01-31-2018, 12:20 PM   #4
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Leave it to Commiefornia...
Bad Anvil Garage is offline   Reply With Quote
Old 01-31-2018, 01:15 PM   #5
crosive
Drives: 18 zl1
while this might work, I seem to remember reading somewhere that leaving those valves closed while going wot for extended periods isn't good for the motor. stealth keeps them shut all the time, but touring mode still opens them up for wot and perhaps even just spirited throttle.
crosive is offline   Reply With Quote
Old 01-31-2018, 01:26 PM   #6
MSMYYC
@maplefed
MSMYYC's Avatar
Drives: 16' MBM 2SS,
Might get away with it on autocross however.. depending on the course, not much time spent at WOT.
@maplefed
MSMYYC is offline   Reply With Quote
Old 01-31-2018, 02:36 PM   #7
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
There is absolutely no truth to this statement. Literally millions of cars have been built with restrictive exhausts since the dawn of the automobile with no adverse effect to engine longevity. I swear. I don't know why people make this kind of stuff up.
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine,
and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or
to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's
race, religion, sex, sexual preferences, handicaps, or intellectual abilities.
ChicagoTommy is offline   Reply With Quote
Old 01-31-2018, 02:40 PM   #8
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Set the exhaust to Tour from the settings page. Lets you "un-sync" the exhaust to the drive mode that way you can have the suspension in Track, but the exhaust in Tour.
Have a watch to see some recorded decibels
Lolwut?
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 01-31-2018, 02:46 PM   #9
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
If you know where the decibel meter is placed...you could have some tips made to shoot the sound the other direction when you go by it. That is what a lot of people do.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 01-31-2018, 02:50 PM   #10
MSMYYC
@maplefed
MSMYYC's Avatar
It’s literally in the owners manual.
@maplefed
Old 01-31-2018, 02:57 PM   #11
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
from what Ive seen people do here at the Qualcomm autox, when their cars are too loud, they use temporary turndown tips like these:
Talk to Ed Hanson of EdHanson's muffler shop. BEST exhaust guy in the business, very helpful and affordable, I usually learn something new every time I see him haha.
Turndown tips will make your car slightly quieter from the outside, but will make it louder inside the car. As others have said, be sure to go to vehicle settings and put the exhaust into tour mode in whichever drive mode you use for racing.
soloknight6 is offline   Reply With Quote
Old 01-31-2018, 03:39 PM   #12
DetCam
DetCam's Avatar
Drives: 2016 1SS (12/10/2016)
I typically have my exhaust set to "stealth" mode when I leave the house in the mornings, and one time I did forget to change it for an autocross event. I had everything else set the way I wanted it (nannies off, Mode selector on "Track"). The steering felt right, but I swear it was behaving more like it was in snow and ice mode.
I couldn't tell you exactly what the difference was: cut in power, different throttle mapping, or both... it just wasn't right. I kept thinking there was something wrong with the car and didn't figure out until after my 3rd run that I still had the exhaust in stealth mode. I put it in track mode for the 4th run, and the beast woke up. Granted, my rhythm was so messed up by the previous three runs I didn't do very well, but at least my car was "normal" again...
My recommendation: don't do any performance driving in Stealth mode.
DetCam is offline   Reply With Quote
Old 01-31-2018, 03:53 PM   #13
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
High Performance Owner's Manual Supplement
The Engine Sound Management
setting should not be set to Stealth
Mode during track events and
competitive driving. See “Driver
Mode Control” under “Ride Control
Systems” in the owner’s manual.
https://my.chevrolet.com/content/dam...supplement.pdf
n
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-31-2018, 04:31 PM   #14
IH8WNTR
Drives: 2017 1SS 1LE Silver Ice Metallic
Yeah. Totally sucks doing an autocross course in the dead of winter....
IH8WNTR is offline   Reply With Quote
