Old 01-30-2018, 06:55 PM   #1
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
When do you start having stabilitrac issues when changing to different tires?
I'm looking to change out my wheels and tires. I plan on going with a set of the MMR M017's. On the back I have looking for a tire that will hook well, my car is full bolt, E85, M6. I have only taken it to the drag strip a couple of time. I have been looking at the NT 555R 305/35R20's for the rear. They are advertised as 28.58" tall. I realize that I would likely have to move the rear wheel well harness, no biggy. My issue is finding front tires that will work with these rear tires and not mess up the stabilitrac. I have looked at the NT 555 G2's, one in 275/35R20 which is advertised as 27.56" tall, and the other in 285/35R20 which is advertised as 27.87" tall.
When do the diameter difference between the front and rear tire start to cause a problem with the stablitrac?
Does anyone else run this set up or a similar set up?
What is your recommendation?
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 01-30-2018, 07:34 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
it happeneded to me when i switched to bigger wheels and tires but would usually go away within a day or so
Old 02-01-2018, 08:29 PM   #3
PrestonKnots
Drives: 2017 Camaro SS
I have the MRR 650 wheels with 275/35 20 fronts and 295/35 20 rears, stock ride height no issues. I wouldn't go bigger than the 275/35 on the front, tight fit but no issues.
PrestonKnots is offline   Reply With Quote
Old 02-01-2018, 08:32 PM   #4
travislambert
Drives: '17 ZL1
I created a related Ask Al question.
http://www.camaro6.com/forums/showthread.php?t=519726
travislambert is offline   Reply With Quote
