Old 01-29-2018, 12:57 AM   #1
lewisd
2016 SS A8 rough 1-2 shift?
I bought a used 2016 SS with the automatic a few weeks ago. Largely happy with it, just one thing that's been bugging me a bit.
When I'm driving it sedately, in "tour" (which has been a lot lately with the crappy weather) I've noticed that the 1-2 shift can be a bit rough and jerky. The other shifts are fine, and if I'm giving it a good amount of gas, 1-2 is fine, it's just if I'm accelerating slowly that it's jerky.
Is this just the way the transmission is, or is it something that should be looked at?
Current stable:
2019 Camaro 2SS (same as 2016 but 10AT)
2014 Subaru WRX (Satin White Pearl, Kenwood Carplay headunit)
Past stable:
2016 Camaro 2SS (8AT, NPP Dual Mode Exhaust, Magride, sunroof, Summit White, black metallic center stripe, Adrenaline Red interior trim)
1990 Mazda Miata (too many mods to list)
1988 Mazda 323 Wagon (With 323 GTX motor!)
1987 Monte Carlo SS (Grey on grey, gunmetal-grey painted GTA wheels, lowered, dual exhaust, and much more)
2006 Subaru Impreza
1981 G20 Van (3-tone brown, shag/velvet interior)
lewisd is offline   Reply With Quote
Old 01-29-2018, 01:39 AM   #2
Razzaa
Razzaa's Avatar
It’s pretty common with the A8. I could be wrong but I believe it is because of the AFM.
Razzaa is offline   Reply With Quote
Old 01-29-2018, 07:21 AM   #3
crosive
Drives: 18 zl1
mine does this on occasion, but usually because it hasn't warmed to operating temperature yet. I've not noticed it when its had enough time to warm up.
crosive is offline   Reply With Quote
Old 01-29-2018, 08:17 AM   #4
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
This!
craigss50 is offline   Reply With Quote
Old 01-29-2018, 08:43 AM   #5
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Mine does it too. It’s just a really hard 1-2 shift, that seems out of place when driving conservatively. But I’ve noticed it after sufficient warm-up time too!
blazzin1 is offline   Reply With Quote
Old 01-29-2018, 09:38 AM   #6
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Good luck getting GM to do anything about it. It is a common complaint on this transmission. Mine does it on the first shift of the morning and in the summer when the trans temp gets up to 150, it will do it everytime while you are driving lightly. If you get stuck in stop and go traffic while its doing this, it will drive you insane. I even switched to the new recommended GM/mobile one transmission fluid and it made ZERO difference. This A8 trans is horrible in anything but all out acceleration.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 01-29-2018, 10:04 AM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Wrong- Not the AFM.... it needs a fluid flush and trans reprogram.
Old 01-29-2018, 10:48 AM   #8
DiGiam
DiGiam's Avatar
Ive had 3 flushes, torque converter changed, fluid changed to the new GM Dexron HP and reprogramed. Its still the same. Just waiting until I get the car paid down a little more and this sucker is outta here. No more Camaros for me unless the refresh has the A10 and even then ill wait to see what issues people have. GM screwed the pooch on the A8. Great idea that was poorly executed
Old 01-29-2018, 10:50 AM   #9
init4fun
Drives: 2017 50th Anniversary
Mine does this on the first couple of shifts in the morning. Let the dealer know the next time you take it in. They will reprogram the trans and more than likely flush the fluid.
init4fun is offline   Reply With Quote
Old 01-29-2018, 12:29 PM   #10
lewisd
Thanks for the info folks.
Mine is doing it warm or cold, doesn't seem to matter. I'll mention it next time it's at the dealer, see if they can do anything. If not, no biggie. Mine's not bad enough to put me off the car, just mildly annoying.
Current stable:
Past stable:
2006 Subaru Impreza
Old 01-29-2018, 12:42 PM   #11
Capisce
Drives: 2016 2SS Camaro
Mine does it only cold, first shift leaving in the morning
2SS - Summit White - MRC - NPP
Capisce is offline   Reply With Quote
Old 01-29-2018, 12:43 PM   #12
craigss50
craigss50's Avatar
I've never had much luck with GM automatic transmissions. I should have known. I have the rough 1-2 shift when cold and it feels like the torque converter lockout is cutting in and out at about 45 mph when trans is warmed up. Loved my M6 in my Corvette. Should have saved the extra money and got the manual.
Old 01-29-2018, 01:05 PM   #13
solarstingray
Drives: 2014 c7 corvette and 2017 camaro ss
I am in the same boat,
might be picking up the new alfa romeo giulia quadrifoglio or a audi rs3
solarstingray is offline   Reply With Quote
Old 01-29-2018, 01:52 PM   #14
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
FOR ALL THOSE EXPERIENCING THIS ISSUE:
HERE IS THE FIX:
While its not exactly a PROBLEM persee, GM is aware of this issue and there IS a fix for it... There is actually TSP issue related to the TCM. I was experiencing this and took it in and they re-calibrated my TCM and the issue went away. It hasn't been doing it since... Here...read my thread and at the very end you will see the solution:
http://www.camaro6.com/forums/showthread.php?t=518185
Need4Camaro is offline   Reply With Quote
