![]() Drives: 2018 Camaro V6 2LT RS M6 Join Date: Oct 2017
NPP exhaust questions
Can someone help me with a couple questions regarding the NPP exhaust sound?
1) When switching driving mode between Tour and Sport, does the exhaust loudness change automatically or must it be changed manually using the engine sound management settings located in the infotainement system? 2) Can you drive in Tour mode and keep the exhaust system in the loud mode? Thank you for your help. |
#2 | ||
![]() Drives: 2017 2LT RS Join Date: Oct 2017
Note that even when set to Sport (and Track for the V8), the NPP valves will still close under certain conditions. To keep them open all the time, you'll have to pull a fuse or buy a third party controller like the Forza or Mild2Wild. Lots of threads here regarding fuse pulling and controllers so I would suggest a search if you're wanting to do that. Hope that helps! |
![]() Drives: 2018 2SS M6 Hot Wheels Camaro Join Date: Mar 2017
Pull a fuse? I have my driving mode set to Touring, but in Engine Sound Management I set exhaust to Track. Isn’t that going to be the best setting for keeping the exhaust note the loudest? I may be wrong, so these are my questions:
Is Track the best and loudest setting for NPP in Engine Sound Management? Do they stay open all of the time in this mode, or is it essentially just like Sport mode, and if so, why the two different exhaust modes?
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars: 2017 1SS Nightfall Gray Metallic w/A8 and NPP 1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps. |
#4 | ||
In regards to specific NPP differences between Sport and Track, I'm not entirely sure since I don't have Track available in my car. I would guess it has a slightly different threshhold at which the NPP engages, or they stay open longer. |
![]() Drives: 2015 Camaro 1SS Join Date: Dec 2017
#6 | |
