Old 01-26-2018, 08:31 AM   #1
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
ZL1 1LE Wing Install DIY
I'm mid-process of doing the ZL1 1LE aero on my ZL1 and I wanted to share my process of installing the ZL1 1LE wing on my car. I watched the only video I could find on the subject and while the Video was very helpful to start, I found it lacking in ideal guidance on the R&R of the ZL1 wing. Not a clear set of steps and a really bad technique was used prying the wing off instead of heating the double-sided tape to make a clean and easy release.
(quick note: I really appreciate the video and will add this DIY/Link in the comments on Youtube, but all things can be improved)
After watching the video, please follow these steps:
Tools needed:
- Heat gun
- 10mm 1/4 drive socket (swivel)
- 10mm gear drive wrench with a flexible head
- Large Bath towel
- Small towels x 2
- Painter Tape
1) Remove the inside trunk lid liner & Place Large towel over the trunk latch
2) Back out all 6 anchoring bolts to the last 2 threads
3) Visually locate the white plastic retaining anchors (these are connected to the OEM wing)
4) Use painters tape to protect your trunk lid on both sides of all 3 wing anchor points
5) Use a heat gun to evenly and thoroughly heat all 6 mounting points (you want the underside surface just too hot to touch with your bare skin)
6) Gently pry the OEM wing up by hand, double-sided tape should immediately release some, if it doesn't add more heat
7) Gently rock the OEM wing fore & aft to release all of the double-sided tape
8) Remove 5 of the 6 anchoring bolts, leaving the easiest middle bolt in place with just 2 threads holding it on.
9) Use a flat blade screwdriver or other tools to release the white plastic retainer on one side of the OEM wing. (it's okay to break it, won't be used again)
10) Use a small towel to keep the wing/plastic retainer from resetting into the deck lid hole.
10) Repeat step 9 on the opposite side.
11) Remove the middle bolt and slowly/carefully lift OEM wing off the deck lid
12) Clean and Polish the deck lid surface
13) Remove double sided tape backing from 1LE wing
14) Deploy wing into Deck Lid, it can really only go in one way, be careful go slow and don't scratch anything
15) With everything aligned, press the wing down on the decklid lightly (5lb of pressure from the mount points (NOT THE WING) to get a good initial seat.
16) Get the 6 anchor nuts in place and gently tighten them from the inside out positions, slowly, to suck the wing fully into place. Be smart, go slow, these don't need to have a lot of torque, inch lbs here not sure of the exact spec, but very snug.
17) COMPLETE
Hope this helps someone out there!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-26-2018, 08:49 AM   #2
Eddie-v
Drives: NGM ZL1 1LE
Beautiful!!
Eddie-v is offline   Reply With Quote
Old 01-26-2018, 09:21 AM   #3
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Damn it looks killer on NFG! And ignore the peanut gallery that will likely be showing up to tell you the wing will destroy your decklid. Not a single person has provided any evidence of such, and the trunks are visually identical on 2017/2018 Cars. (If yours happens to be a 2017 That is)
The creator of that video is on this forum BTW. Same
Screen name. Watch his firearm videos from time to time over the years.
ninetres is offline   Reply With Quote
Old 01-26-2018, 09:22 AM   #4
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Jelly of your garage!
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 01-26-2018, 09:27 AM   #5
Sakudog
Sakudog's Avatar
Peanut Gallery will come spewing misinformation as they always do and the trunk will be fine as it is the same trunk on a 1LE and yes I have a 2018 car.
The guy who made the video is awesome and I'm very thankful for him, but there is a slightly better way to get do the swap and I wanted to share it.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-26-2018, 09:29 AM   #6
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Nice detail.
JB'sZL1 is offline   Reply With Quote
Old 01-26-2018, 10:05 AM   #7
Infern0
Bring It
Infern0's Avatar
Drives: In Between
lol love the sweater.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 01-31-2018, 02:59 PM   #8
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Tools needed:
- Heat gun
- Large Bath towel
- Small towels x 2
- Painter Tape
17) COMPLETE
Look at that carbon fiber induced smile!
Old 01-31-2018, 03:04 PM   #9
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Looks awesome! Nice job.
Old 01-31-2018, 03:05 PM   #10
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Nice!
Off topic question... I'm ordering a cover, what is the wing height (deck lid to wing top)?
I'm unable to find by searching forums.
Thanks in advance.
2018 ZL1 1LE sw/PDR
Old 02-01-2018, 09:22 AM   #11
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
Thank you for this
SoCal Racer is offline   Reply With Quote
Old 02-01-2018, 09:15 PM   #12
Sakudog
Sakudog's Avatar
So I've finished up the Canard install and after a few days thinking it over, I think I'm going to stick with the base splitter because I think it just looks better.
The ZL1 1LE splitter (to me and just my opinion) doesn't look great. So I've decided I will run an ARP Splitter for the base ZL1 on track days but keep the stocker as the mosaic black paint also flows the rest of the body.
https://cdn.shopify.com/s/files/1/08...ge_proxy_6.jpg
Time to enjoy the car!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 02-03-2018, 04:26 PM   #13
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Looks great, and damn you were close to closing the door on your rear end..I have already :(
After installing the canards, did it seem like you could have done so over the DRLs? Perhaps a small "notch" could have been carved if it would have rubbed? I'm wondering how that would look.
Old 02-03-2018, 04:38 PM   #14
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
My thoughts exactly... that’s a 2+ million dollar property in LA ;(
I’m not there yet...
Oh , and great detail on the install writeup. Can the mods make this a sticky?
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
