![]() Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
How to replace stock tweeters
As the title states, I wanted to see how I can get to the stock tweeters in my 2018 SS 1LE. I have some new tweeters that I am going to be replacing my stock ones with but don't know how to remove the dash or access the stock tweeters. I will be using the oem tweeter location. The car is a 1LE so I don't have an amp. Basic 6 speaker system. Any advise helps me out a lot. Complete overhaul of sound system will be posted soon.
JL Audio 750/1 amp JL Audio Slash 300/4v3 amp STEG ST650C components up front JL Audio 12W7 sub ported JL Audio FIX-86 Digital sound processor Thanks again guys. This is my first post. |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I'd like to tell you that it's relatively easy but, then I'd be lying. It's not difficult because of all the steps needed to remove them. That's actually the easy part. Pull off the pillars. Yes, just pull them off. No screws involved there, just clips. Once you get those off, you'll see exactly what needs to be unscrewed. The trouble is unscrewing it. The passenger side is a bit easier to manage but, unless you have a right angle screwdriver capable of working in such tight conditions, you're going to be fighting and swearing up a storm. The driver's side is horrible because of the dash molding being in your arm path. It was a very frustrating task. I didn't even replace the tweeters. I just wanted to disconnect them because I bought 2-way speakers for the doors and didn't want to cut wires going to the tweets. I should have just found them and cut them. Would have been easier. Good luck.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Thanks. Ill get onto doing this today. Ill probably use my ratchet wrench with a 6mm and Phillips head to get to those screws.
![]() Drives: 2018 1LT Join Date: Nov 2017
flcusat
#7 |
![]() Drives: 2017 Silver SS Convertible Join Date: Dec 2018
#8 |
![]() Drives: 2020 1SS 1LE Join Date: May 2020
I’ve been looking for a video for this online, but I’ve been unable to find one. Sorry for the Necro bump, but it’s a valid question still.
#9 |
![]() Drives: Chevy Camaro Join Date: Apr 2020
5 star car audio has a full install video on a gen 6. They install tweeters in the factory location. They cut the stock tweeters out of the brackets and use them to mount the new ones
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Here's another video that shows this, but with a big caveat: How to Install speakers, take apart interior, amp kit in 6th gen Camaro with OEM radio. The caveat: DO NOT CUT THE BUNGEE CORDS LIKE HE DOES!!! That bungee is there to keep the trim piece from becoming a projectile if your air bag goes off. For obvious reasons, that is important. There's a clip to pry open so you can slip the bungee connection off and remove the A-pillar trim piece completely. The Five Start video sort of discusses it, but you can't really see what they're showing you very well. This is a picture of the clip: The open end is facing down the pillar toward the dash, and you need to pry it open a bit and then slide the clip up toward the roof. It takes some muscle. This video shows pretty well how the trim piece is popped off its clips, though. My advice here is to be really careful not to pull them too far off when they break loose, or else you'll pull apart the little microphone in the pillar that you need for voice commands and hands-free calls. Ask my how I know. Luckily, they are cheap to replace. This video also gives a good sense of the one tough screw on the driver's side tweeter. It's the one closest to the windshield. But honestly, you just need a 7mm combination wrench and some patience. You just turn it 1/8-1/4 turn at a time, and in a minute or two you'll have it out. This is not one of the harder fasteners I've ever had to deal with. The other screw on this tweeter and the two on the passenger tweeter are not hard. A 1/4"-drive ratchet and shallow 7mm socket work fine.
Matt Miller
2020 SS 1LE |
#11 |
Thanks guys!!!
| Tags |
| tweeter removal |
