Old 01-23-2018, 03:05 PM   #1
Silver2ssA8
Drives: 2017 Silver SS
Thousands of specks of sap
So my car is covered in sap from sitting at the dealership, thought it was overspray but luckily it’s not. However I cleaned the windshield and it took a lot of windex and scrubbing to remove it. What’s the safest way to remove it from the paint without scratching it? I was thinking of using warm water but I wanted to check with you guys to see what you think
Silver2ssA8 is offline   Reply With Quote
Old 01-23-2018, 03:14 PM   #2
Burly
Burly's Avatar
I would start with a couple of warm and thick soapy washes, probably just use Dawn soap.
Burly is offline   Reply With Quote
Old 01-23-2018, 03:18 PM   #3
Silver2ssA8
Yeah I’ll try that, I just want to be as careful as I can since it has been repainted in a few areas too
Old 01-23-2018, 03:32 PM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
If it’s tough, mineral spirits is safe for paint. Let it dwell a bit before wiping.....
Old 01-23-2018, 03:56 PM   #5
timmy8784
Drippin' Wet Auto Detail
timmy8784's Avatar
Always had good luck with Tree Sap with Gyeon Tar
https://www.amazon.com/gp/product/B0...9c531035cedd11
timmy8784 is offline   Reply With Quote
Old 01-23-2018, 04:23 PM   #6
Cobaltct
Drives: 2018 camaro ZL1 in Nightfall Grey
I second this, also a clay bar will work
Cobaltct is offline   Reply With Quote
Old 01-23-2018, 04:43 PM   #7
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Hand sanitizer will remove tree sap easily. It does contain alcohol, so you will need to re-apply protection to your paint after use.
The repainted area has to gas out (cure) completely before you can apply a wax or sealant on it, so for the repainted areas, don't put wax or sealant on them until it is fully cured, usually 60-90 days.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 01-23-2018, 04:46 PM   #8
Silver2ssA8
It’s weird that the body shop waxed the repainted areas.. so maybe it’s good to strip the paint. But otherwise it’s fairly safe to wash it?
Old 01-23-2018, 05:57 PM   #9
Joe M 2012 2SS
Drives: 2012 2SS
Yes you can wash it with no issues.
Old 01-23-2018, 06:01 PM   #10
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
CarPro Tar X, it works wonders
warren3537 is offline   Reply With Quote
Old 01-24-2018, 09:23 AM   #11
68Vette
Drives: 1SS Hyper Blue Metallic, MRC, NPP
To echo what Glen said, either mineral spirits or Zippo lighter fluid in which both are petroleum based so their safe on the clear coat. I use the Zippo fluid to remove road tar from the rocker panels and rims.
68Vette is offline   Reply With Quote
Old 01-24-2018, 09:37 AM   #12
V8Snob
Drives: SS Camaro
Maybe try washing the car?
V8Snob is offline   Reply With Quote
Old 01-24-2018, 11:56 AM   #13
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
I've had it on other vehicles of mine and warm, to a little hot with good amount of suds would always take care of it. now, if its been sitting on the pain long time? well not sure if you need a different route. But if I see something like that, I never let it sit for more than a few days.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-24-2018, 12:10 PM   #14
Silver2ssA8
Yeah it’s been sitting on the car for about 5 days now, I’ve been waiting on some stuff I ordered to wash the car safely, it’s been sitting in my garage so I’m hoping it won’t get any harder to remove. I’m afraid to touch the thing!
