Old 01-22-2018, 08:53 AM   #1
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Can mylink connect to iPhone hotspot?
I remember being able to view apps such as the weather channel on mylink when I was still under the free trial period with onstar, but now that I have unlimited data on my iphone 8 can I reverse the connection and get mylink connected using the mobile hotspot on the iphone to make the mylink apps work again?
Old 01-22-2018, 09:30 AM   #2
GTPprix
I hack cars.
Drives: Lots ;)
Yup!
GTPprix is offline   Reply With Quote
Old 01-22-2018, 09:52 AM   #3
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
Originally Posted by GTPprix View Post
Yup!
How or where in manual must have overlooked this?
Chevyman2 is offline   Reply With Quote
Old 01-22-2018, 10:27 AM   #4
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Yup!
Awesome! How do I set it up. I know how to get the hotspot on the phone working but how do I connect the car to it?
Old 01-27-2018, 01:48 PM   #5
harrisrwe
Drives: 17' 1SS Vert, Nightfall
It's in the "Shop" settings. If you open the Shop it should try to connect to the default (Onstar) and then ask you if you wanna adjust the settings when it can't. You can probably find it in the normal settings though.
harrisrwe is offline   Reply With Quote
Old 02-02-2018, 01:54 PM   #6
srcstc
So if you have a 2016 model without the shop you can't do it?
srcstc is offline   Reply With Quote
Old 02-02-2018, 03:51 PM   #7
DanSnow
Drives: 2017 Camaro 1LT 2.0T
Scroll through your settings I believe there is an "Internet" or "Wifi" subsection somewhere in there.
DanSnow is offline   Reply With Quote
Old 02-03-2018, 09:17 AM   #8
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
You won't find "Connect to hotspot" mentioned so to speak in the manual. It does mention connecting myLink to WiFI.
Correct, in Settings there is a WiFi menu. Pick your AP and type the password...done.
Old 02-04-2018, 05:27 AM   #9
srcstc
Looked everywhere, it's not there. Found a WiFi menu but it only lists the car's SSID & password.
Old 02-14-2018, 08:28 PM   #10
FERRARI
Drives: 2017 ZL1 10 Speed Auto
How to use your iPhone as a 4G LTE Wi-Fi hotspot
This works on a 2017 ZL1.
Make sure your iPhone’s data plan is sufficient for both your phone and auto usage.
Power iPhone thru console (not thru CARPLAY Aux port)
On iPhone:
SETTINGS:
DISPLAY & BRIGHTNESS - AUTO-LOCK —> NEVER (this ensures your iPhone will not automatically shut off thus disconnecting the hotspot)
WIFI —> ON
PERSONAL HOTSPOT - PERSONAL HOTSPOT —> ON
Use PASSWORD shown to set up MYLINK WIFI
After WiFi setup before starting car, Turn on iPhone to PERSONAL HOTSPOT which will now be discoverable by car.
SETTINGS - CELLULAR - CELLULAR DATA —> ON
On car:
MYLINK
SETTINGS:
WIFI
WIFI —> ON
MANAGE WIFI NETWORKS
ADD OTHER NETWORK
IPHONE, security WPA2, use PASSWORD from iPhone personal hotspot
After setup you may have to occasionally go to MANAGE WIFI NETWORKS and select IPHONE from available networks
Previous cars:
1964 Pontiac GTO
1967 Pontiac GTO
1969 Pontiac GTO Judge
2004 Pontiac GTO
2006 Pontiac GTO
FERRARI is offline   Reply With Quote
