Old 01-19-2018, 12:19 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
Hellion Twin turbo systems available today through JRE
Hellion twin turbo system are ready to ship today.
Ceramic coating standard, Turbo Blankets standard, heat wrap all standard, this one of the most premium kits we have ever seen and are excited to offer this kit in 2 stages.
Stage 1 up to 600 RWHP
Stage 2 requires LT-4 fuel system upgrades up to 750 RWHP
Stage 3 requires Camshaft upgrade up to 850 RWHP
Stage 4 will be forged internals and supplemental fuel system.
All without changing a single part in the kit.
We are offering a special deal on the First of this kit installed at our facility in any of the above stages, Be the first to get this amazing package installed on your car.
Features copied from the site
The most powerful option for the 2016+ Camaro SS is finally here! This top mount twin turbo system has taken the LT1 engine to new heights. The base system provides 5-6 psi to gain over 180-200whp! Modified fuel systems and supporting mods will allow over 1200whp to be made! This system is a true bolt-on. The Gen 6 now has the power adder it deserves!
System Highlights:
Top mount stainless turbo headers
Twin Precision 6266 CEA® turbos (v-band inlet for easy installation)
Large vertical flow core intercooler (highest flow bar/plate core available)
Twin Precision 40mm wastegates (v-band inlet for easy installation)
Dual blow-off valves standard (hear that rush every time you hit the throttle!)
All necessary heat protection included in the system ceramic coating standard
NOTE THIS IS A TUNER KIT ONLY NO FUELING OR TUNING IS INCLUDED
Contact me for details.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-19-2018, 12:42 PM   #2
Calubi
Drives: 2017 1SS 1LE
Is stage 1 effectively the kit as shipped by Hellion, with stage 2+ being additional parts added on by you?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 01-19-2018, 12:44 PM   #3
JANNETTYRACING
Correct, again with no changes to the kit itself.
Ted.
Old 01-19-2018, 01:28 PM   #4
Calubi
Any insight into how streetable these turbos are compared to something like a procharger D-1SC, assuming a 600whp level on an M6? Would you lose a lot of low end due to spool? Or are these turbos small enough to spool reasonably low in the RPM band?
Old 01-19-2018, 02:37 PM   #5
JANNETTYRACING
Almost seamless, You control the boost with the pedal, it drives like stock until you request more power, turbo spool is well on its way at 2.5-3K all in by 3.5-4K or lower depending on conditions.
Feel free to give us a call with any questions.
Ted.
Old 01-20-2018, 03:22 AM   #6
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
im a turbo guy all the way but do not like the twins on this kit being under the hood with the heat, and the amount of stuff that has to be moved from factory positions. i wish AGP's kit could squeeze bigger turbos down there to make more power than 800.
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 01-20-2018, 08:03 AM   #7
JANNETTYRACING
I understand your position, but I feel they are in an Ideal location, no Oil pumps to mess with, and allow many turbo options, plus you get tubular headers included.
Ted.
Old 01-20-2018, 08:09 AM   #8
Calubi
Is heat really that big of a concern with ceramic coating and turbo blankets?
Old 01-20-2018, 08:15 AM   #9
JANNETTYRACING
No.
Old 01-20-2018, 07:33 PM   #10
SilverSS1LE
motor maintenance is more of a hassle with top mounted turbos.
Old 01-20-2018, 08:11 PM   #11
TEX1LE
Drives: 2017 1LE - Blue
System Highlights:
Ted.
Do you know if this kit has been tested on a road course to see if overheating will be an issue?
TEX1LE is offline   Reply With Quote
Old 01-21-2018, 09:13 AM   #12
Calubi
Do you have to pull the turbos to get to the plugs? It looks like there should be room from the pictures. Or are you referring to something else? The oil fill looks a bit tight, but nothing a good funnel wouldn’t fix.
Old 01-22-2018, 08:59 AM   #13
JANNETTYRACING
Although it is different I would not say it is harder the kit is very well thought out.
Ted.
Old 01-23-2018, 03:47 PM   #14
JANNETTYRACING
Lots of inquiries but no one has taken advantage yet don't miss out on this great deal will save you 1K off package installed.
Ted.
