Old 01-18-2018, 10:17 PM   #1
JPAT
Drives: 2018 Camaro V6 2LT RS M6
Front turn signal
Has anyone upgraded the front turn signal from OEM bulbs to LED?
Thanks
JPAT is offline   Reply With Quote
Old 01-19-2018, 06:44 AM   #2
ecko04
Drives: Too many to list
Front turn signal
Yes. You’ll need to also install resistors to eliminate hyper flash.
You can splice a resistor in-line yourself or use plug and play resistors to save the time and preserve the factory wiring.
Here’s a link to a plug and play resistor:
https://www.amazon.com/dp/B0776VSK85..._3ODyAbA4QG2QC
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 01-19-2018, 08:53 AM   #3
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Not to sharp shoot but you would need to install load capacitors, they sell the at the parts stores and even Walmart.
warren3537 is offline   Reply With Quote
Old 01-19-2018, 10:16 AM   #4
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
We replaced our Camaro's front turn signals with XP80s:
Front Turn Signal LEDs for 2016-2017 Chevrolet Camaro
It cleans up the look of the front end when the bulbs are off. You don't see the amber reflection inside the housing with any of our options installed.
Thanks!
Nick C.
Diode Dynamics is offline   Reply With Quote
Old 01-19-2018, 07:20 PM   #5
chris227
chris227's Avatar
Led blinkers was the first mod I did. Super easy and looks great.
http://www.camaro6.com/forums/showth...13#post8934113
I also posted a link to the bulbs I used in the thread above. Almost 2 yrs with them and not one issue.
