Old 01-16-2018, 08:13 PM   #1
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
2019 Camaro Available with 7 speed Manual and Stays with the 8 Speed Auto?
CARB published the 2019 certification for what should be the LT1. The Camaro and Corvette are listed, and the M6, M7, and A8 are listed for the Camaro. This could also mean the LT1 Camaro won't be getting the A10. Nothing is guaranteed with CARB certifications. They are sometimes superseded with updates. But the Camaro is now certified for the M7.
https://www.arb.ca.gov/msprog/onroad...6d2_l3-160.pdf
For comparison, this is the 2018 CARB ceritifcation showing only the M6 and A8:
BahamaTodd is offline   Reply With Quote
Old 01-16-2018, 09:34 PM   #2
WhyUMad1LE
Drives: 17 SS 1LE
They would be better served to keep the 6 speed manual and add the 10 speed auto. I haven't seen many people asking for another overdrive in the manual.
Old 01-16-2018, 09:39 PM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Interesting. Thanks for posting!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 01-16-2018, 09:45 PM   #4
OMEN
OMEN's Avatar
Drives: Camaro SS
hopefully we get the A10 so that i can trade mine for it
2017 2SS RED HOT
Instegram:@Monther1988
Oman Camaro Team
Middle East, Oman
1LE front splitter, ZL1 Corsa Xtreme quad tips, x pipe, ZL1 Rear Diffuser, 1/LE Rear Emblems
CoCo 4 Life
OMEN is offline   Reply With Quote
Old 01-16-2018, 09:57 PM   #5
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
I have a Z51 vette with a M7 transmission
6 gears were enough, the 7th really is marketing fluff. I agree that they would be better served putting the A10 and M6 in
Nothing wrong with the M7, just not needed
devnull is offline   Reply With Quote
Old 01-16-2018, 10:49 PM   #6
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
GM isn't going to leak the info via carb.
Look for the A10 at least in the SS, if not the entire 2019 Camaro line.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-17-2018, 12:24 AM   #7
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Starting to think the Z/28 is a pipe dream and a stripped down track beast Manual ZL1 might be coming with a M7. Maybe they are steering clear of the Z/28 moniker as they simply do not have a N/A motor that they want to use....
ZR1 motor with M7 manual in a Camaro ZL1 uber track edition car...
Sledgehammer70 is offline   Reply With Quote
Old 01-17-2018, 01:24 AM   #8
samurai
samurai's Avatar
Drives: C8 Corvette
This would pretty much fit the spied ZL1-based mule. I'm pretty sure the Z/28 will be like every highest-performance-model and only release in the last 1-2 years of the 6th gen, so it should still be a bit away atm
samurai is offline   Reply With Quote
Old 01-17-2018, 01:29 AM   #9
WhyUMad1LE
Drives: 17 SS 1LE
1) This document is for the LT1 engine. If it was for all engines it would include the A10.
2) How would a 7 speed manual improve track performance?
Old 01-17-2018, 06:33 AM   #10
Biscuit.fr
Drives: Red hot ZL1 A10 2017
2) may be with shorter ratio in the first 4 or 5 gears
And mpg improvement with the 6-7...
Biscuit.fr is offline   Reply With Quote
Old 01-17-2018, 07:21 AM   #11
travislambert
Drives: '17 ZL1
The extra gear is only an overdrive gear. Both the M6 and M7 will always have a 1:1 ratio in forth, so these transmissions for all intents and purposes are equivalent in the first 4 gears.
travislambert is offline   Reply With Quote
Old 01-17-2018, 09:06 AM   #12
Bhobbs
Bhobbs's Avatar
Pretty sure the M7 doesn’t fit the Alpha trans tunnel, which is why no alpha cars have it.
Old 01-17-2018, 09:28 AM   #13
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Agreed that was the reason it wasn't included in any Alpha car. A refresh certainly isn't going to fix that problem.
Old 01-17-2018, 10:04 AM   #14
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Right but the extra overdrive allows for much more aggressive gearing. Most M6 cars came with 3.42 or 3.73 depending on tire height and they really need 4.10 or 4.30 for better shift extension and keep the engine in it's power. The M7 allows this and keeps RPMs down while interstate cruising.
