Old 01-15-2018, 11:46 AM   #1
oldman
Drives: SS 6 speed of course
bmr engine mounts
since my engine is out what about either:
BMR mount setups:
http://m.bmrsuspension.com/?page=pro...productid=1778
http://m.bmrsuspension.com/?page=pro...productid=1777
I'd like to see a picture of either installed. thanks!
Old 01-15-2018, 11:49 AM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I should have the top link by the weekend! Hopefully I can round up some helpers and put the motor back in
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 01-15-2018, 11:50 AM   #3
parish8
Drives: 17 SS a8
I have a set of the top one you linked to on the way. It may be a month before I put them in. Looks like they should free up a ton of room.
Old 01-15-2018, 11:55 AM   #4
oldman
Yep, there are pics with the mount installed but with no header. I'd like to see how it looks with the header.
Old 01-15-2018, 11:59 AM   #5
Dubchitts
Dubchitts's Avatar
I'll let you know how they are with kooks 1-7/8
"Spitfire" 427ci
Old 01-18-2018, 10:13 PM   #6
WallsAndFoundations
IG: Infinite.Drive
WallsAndFoundations's Avatar
Drives: 2016 Camaro 2SS in Summit White
BMR mount setups:
What's the difference between the 2 variants? Different part numbers, both seem very similar. I've been interested in those as well!
________
Fight your mind
WallsAndFoundations is offline   Reply With Quote
Old 01-18-2018, 10:21 PM   #7
Dubchitts
Dubchitts's Avatar
Did you even look at the pics?......
"Spitfire" 427ci
Old 01-19-2018, 11:01 AM   #8
oldman
looks to me one is a full mount, from K member to engine, the other looks like it is the insert into the K member you still use the factory bracket / mount to block. I don't have either, just going by the picture.
Old 01-19-2018, 04:36 PM   #9
parish8
Drives: 17 SS a8
My mounts showed up today. They look strong.
I weighed them. The bmr saves about 2 lbs on the passenger side and 3.5lbs on the drivers side.
Old 01-19-2018, 04:57 PM   #10
Dubchitts
Dubchitts's Avatar
I'm jealous. Lol. Mine fell off the shipping pallet and won't be here until monday
"Spitfire" 427ci
Old 01-20-2018, 02:25 AM   #11
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
Why is it that all of BMR's stuff is red online and then when you see the part after someone post a picture of it received its that cheap looking splattered black and grey?
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 01-20-2018, 03:17 AM   #12
parish8
Drives: 17 SS a8
You pick the color. Red or this color. I prefer this color.
Old 01-20-2018, 11:20 AM   #13
oldman
red is always faster.... I'm going with black cause I hate the bling... even though it is faster.
Old 01-25-2018, 10:42 PM   #14
Dubchitts
Dubchitts's Avatar
......spot the problem that is really irritating me rn
"Spitfire" 427ci
