Old 01-15-2018, 11:25 AM   #1
lsp408
Drives: 2018 HB ZL1 M6
Menu Items Missing...
I was looking for easy memory recall under comfort and convenience tree, the only thing showing is Chime Volume...
Below are the items missing...
Auto memory recall
Easy exit
Reverse mirror tilt
Anyone have any idea?
lsp408 is offline   Reply With Quote
Old 01-15-2018, 03:00 PM   #2
Boost or bust
Drives: 2018 ZL1 M6
Check with your dealer...I recall seeing aTSB addressing this issue.
Boost or bust is offline   Reply With Quote
Old 01-15-2018, 03:48 PM   #3
lsp408
Will do. Thanks
Old 01-16-2018, 09:49 AM   #4
Boost or bust
Drives: 2018 ZL1 M6
Auto memory recall
Easy exit
Reverse mirror tilt
Here is the link to NHTSA. There are a total of 23 GM communications to dealers. There at least 2 regarding your issue.
https://www.nhtsa.gov/vehicle/2018/C...Communications
Old 01-16-2018, 09:52 AM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Just for grins, let the software reboot and see what happens.....pull the neg batt cable for 30 min and reconnect, you won’t lose the major settings....
Old 01-16-2018, 12:41 PM   #6
lsp408
Thank you all. Will look into those
Old 01-16-2018, 04:59 PM   #7
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
They’ll come back on their own. I lose my steering and suspension options, every couple of months. After a couple of restarts, they reappear.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 01-16-2018, 05:08 PM   #8
FASTNUF
FASTNUF's Avatar
Drives: 2017 ZL1 A10 White Vert
When I use remote start, my Engine Sound Management selection goes away each time. Only comes back when I restart the car by the button.
For the first time last week, the Apple Car Play showed my iPhone playing music, no sound generated through the speakers. When I switched between radio and other ways for sound, showed playing, but nothing until I restarted the car.
FASTNUF is offline   Reply With Quote
Old 01-16-2018, 07:09 PM   #9
lsp408
I guess I will have dealer check it out and also document the issue. Seems like common issues
Old 01-16-2018, 07:25 PM   #10
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Similar issues here, even when using the cable.
This has been a Chevy/GM problem for years though. Wife's car is a '15 Tahoe and it fritz's out when trying to play music through Bluetooth- usually switching to radio and back gets it to work but it's still f-in frustrating.
Old 01-16-2018, 07:32 PM   #11
FASTNUF
FASTNUF's Avatar
Yeah, agree! My 16 GMC Yukon has the same damn problem with ACP too!
Old 01-17-2018, 05:42 PM   #12
Dr.ZL1
Dr.ZL1's Avatar
Drives: 98 WS6 2014 raptor
radio module under passenger dash has to be replaced. I had mine done two months ago. Its better documented in their system now so hopefully you don't have a lot of issues getting them to replace it, mine worked perfect after that
Dr.ZL1 is offline   Reply With Quote
Old 01-17-2018, 06:28 PM   #13
FASTNUF
FASTNUF's Avatar
Thanks Dr.ZL1 for the information. I need to take it in regardless for a creak in my top, so I'll do it all at the same time.
Old 01-18-2018, 10:44 AM   #14
Ironman24
Ironman24's Avatar
Drives: 17 ABM ZL1 M6
My engine sound management menu has disappeared several times after setting the car to stealth to not annoy the neighbors. When I do a cold start and get on the road I can't put the exhaust back into track mode. It will eventually show back up after several starts.
Ironman24 is offline   Reply With Quote
