Old 01-15-2018, 02:00 AM   #1
lopezangel886
Drives: 2016 v6 camaro rs
Need help!!
I’ve lost all hope in searching, I have a v6 with the M6 and as far as I know the 2.0 and the 3.6 share the same transmission. My clutch already went out on my car and there’s no replacement other than oem.. has anyone replaced their clutch yet and if so what type of clutch is it? Thanks in advance!
lopezangel886 is offline   Reply With Quote
Old 01-15-2018, 05:45 AM   #2
EagleRS
EagleRS's Avatar
Drives: Nightfall Grey 2.0L Turbo
WOW!!
What did you do to the poor thing?
Phastek Performance? Depending on your area, Google for a GM performance shop. I know that sounds smart-ass and but in all seriousness, there is a shop I found near where I live. (Buford, GA) This place is called LSX Performance. They specialize on builds for GM vehicles but they are super cool and informative.
Someone may have an alernative / recommendation.
Good Luck, that is rough about your car tho...
EagleRS is offline   Reply With Quote
Old 01-15-2018, 07:07 AM   #3
Johnny2343
Drives: 16 1SS 6mn npp
Zzp
Johnny2343 is offline   Reply With Quote
Old 01-15-2018, 07:28 AM   #4
lopezangel886
The car is FBO and tuned with a higher redline than stock so shifting at the higher rpm really took a toll on the oem clutch.. I’m not gonna lie either I do drive it pretty hard every weekend, I’ve had it tuned like this since around 4K miles so it’s been taking a beating the entire time getting to 21k miles.. never thought that I wouldn’t be able to find a replacement clutch though
Old 01-15-2018, 12:09 PM   #5
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
ZZP in the Cadillac ats/cts section. They have a hevy duty clutch for your set up.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 01-15-2018, 12:41 PM   #6
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
looking at some parts-store style websites, it appears that the 2.0 and 3.6 share a disc, but have different part numbers for the pressure plate and flywheel. i cannot say for sure if our pressure plate will bolt up to a 3.6 flywheel, but it appears that the disc will work. not sure how much help that is.
Zzsteve is offline   Reply With Quote
Old 01-15-2018, 07:22 PM   #7
lopezangel886
Do you guys think I can re-use my pressure plate but just replace the clutch disc with the zzp aftermarket one? I would think it would work fine since the pressure plate is relatively new still (21k miles on it)
Old 01-17-2018, 04:04 AM   #8
lopezangel886
Originally Posted by cooper1965 View Post
You could yes. BUT, you have 21k, and a fried clutch. You are driving the car pretty hard. Now would be the time to replace it with new, and also look at a flywheel upgrade/replacement. You will be money ahead now to throw a few extra $$ at it! Even if you are doing the job yourself, the aggravation saved will be WELL worth the extra minimal cost. Don't skimp on the flywheel bolts either!!
This is just my opinion OFC, the car is yours..
Thank you for the wise words, I may just end up tearing the car down and taking the entire assembly out to send to a manufacturer and have them duplicate it all at once to save the headache as you said!
Old 01-22-2018, 01:37 AM   #9
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
Both SPEC and Centerforce make clutches for the LTG. They list them for the ATS. Obviously they haven't updated to include the Camaro, which has the same drivetrain.
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine,
and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or
to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's
race, religion, sex, sexual preferences, handicaps, or intellectual abilities.
ChicagoTommy is offline   Reply With Quote
