Old 01-05-2018, 09:05 PM   #1
Skyset
Drives: 2017 Camaro 2SS Coupe
Question about MRR M228
Hi there,
I was wondering if the same MRR M228 wheels I had on my 5th gen (20x10 +23 front, 20x11 +43 rear) would fit my 6th gen?
I saw another thread about MRR M228 rims designed specifically for 6th gens....does that mean the 5th gen version will no longer work? I couldn't anything else on this site when I searched.
I am in the process of ordering the same rims I had on my 5th gen, for my 6th gen, just want to make sure I don't order the same size if it no longer fits
Thanks
Skyset is offline   Reply With Quote
Old 01-05-2018, 09:20 PM   #2
HyperBlue16
HyperBlue16's Avatar
Drives: 2016 Camaro RS
Well i think they do, cause the M228 i got last year use gen 5 center caps.
HyperBlue16 is offline   Reply With Quote
Old 01-06-2018, 02:26 PM   #3
Illmaticz
Illmaticz's Avatar
Drives: 2020 Camaro ZL1-1LE
Yo bro you should be fine. My M017's are the same.
Why not get a set of Stance SF06's ??
Originally Posted by Skyset View Post
Hi there,
Thanks
2020 ZL1-1LE A10
2016 2SS A8 (SOLD)
Illmaticz is offline   Reply With Quote
Old 01-06-2018, 03:32 PM   #4
Skyset
Thanks brah.
Dog I just looked at the SF06. Is that the same as a the M228??
EDIT: no I see it's different. Hmmmmm
Old 01-06-2018, 04:44 PM   #5
Soleil
Soleil's Avatar
Yes, they fit. You need spacer for the front otherwise it looks a bit funny. Normally the have +35 in front. Rear is ok as +43 is standard.
Soleil
Old 01-06-2018, 05:08 PM   #6
JeromeS13
Drives: 2017 1SS/1LE
There's no such thing as a "negative spacer"... Adding a spacer to a +23 offset would push it way out of the front fender well. A +35 offset is more sunken into the wheel well, as compared to a +23 offset... 12 mm more inboard...
Old 01-06-2018, 05:45 PM   #7
Soleil
Soleil's Avatar
Yes, exactly. The 6gen MRR 228 use +35 offset. He got +23 so he need a spacer otherwise the wheel will stay too far inside.
Nobody is talking about negative spacer.
Soleil
Old 01-06-2018, 06:06 PM   #8
JeromeS13
If he has 20x10 +23 for the front, he does not need a spacer.
Old 01-06-2018, 10:03 PM   #9
crankaholic
crankaholic's Avatar
The front will poke out 21mm further than stock, and rear will poke out 15mm further than stock. They should fit, but the front tires might stick out just past the fender.
crankaholic is offline   Reply With Quote
Old 01-07-2018, 03:15 PM   #10
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
For clarification to the OP:
Gen 5 SS 1LE front wheel specs were 20x10, +23
Gen 6 SS 1LE front wheel specs are 20x10, +20
The MRR 228 (as do the MRR 017) uses the Gen 5 Specs so you will have 3mm less backspacing. Assuming you will run a 285/30 tire, If you need to run aggressive negative camber for track duty, you may need that 3mm back so a spacer "may" be required in that scenario.
The +35 offset referenced earlier is for the stock 8.5"wide wheels, not the 10" wide wheels. A +35 on a 10" wheel on the front will NOT fit.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 01-07-2018, 03:37 PM   #11
crankaholic
That's a very good point... even the stock 8.5" wheel has a +25 offset. I run 19 x 8.5" wheels with +35 offset for my winter tires and there's barely 10mm between the rim and strut. Actually the 10" +23 wheel might not fit, depending on rim design and tire size.
Old 01-07-2018, 05:03 PM   #12
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
They will fit on both the 5th and 6th en
Only difference is Tire sizes
6th gen recommendation is 285/30 305/30
5th gen recommendation is 275/40 315/35
I did however just do a set of wheels on a zl1 and run 305/315 with no rubbing bough lol
PK Auto Design is offline   Reply With Quote
Old 01-07-2018, 05:06 PM   #13
Soleil
Soleil's Avatar
Wrong. We use in Europe a lot MRR 20x10 ET +35 in front. They fit flush with the fender.
Soleil
Old 01-07-2018, 06:06 PM   #14
LSmith353
LSmith353's Avatar
I'll clarify....
On my 2016 Camaro 2SS with MRC, a +35 10" wheel will hit the strut. With a tire mounted on the wheel, it will not bolt up as the interference prevents the back of the wheel hub to sit flush on the mounting surface. With a +23, I have approximately 5mm of clearance. With a 285 tire mounted, it is closer to 2mm of clearance..
Yours must not be the same as mine......
