Old 01-05-2018, 09:52 AM   #1
parish8
Drives: 17 SS a8
Head studs “with corner studs” ???
https://www.texas-speed.com/p-4410-a...ner-bolts.aspx
Check out the description. It mentions corner studs that you can drill the head out for.
Does anyone know what this is? Is it a bolt that helps keep the head down? Does each cylinder have 4 bolts stock or did they leave one out and un drilled for some reason?
Old 01-05-2018, 10:11 AM   #2
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
i didn't build my long block someone else did I just covered all the costs, all I know is I read this on corvetteforums the other day about the studs not having long enough threads and breaking
https://www.corvetteforum.com/forums...-arp-stud.html
Goertz is offline   Reply With Quote
Old 01-05-2018, 10:15 AM   #3
Omega
Drives: G8
If I read that correctly, the block is drilled and tapped for more bolts than the factory uses. That kit comes with the extra hardware, but you have to drill the holes in the heads to use them.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 01-07-2018, 10:35 AM   #4
laynlo15
Drives: 2022 Lt1 A10
I may pull my heads off for porting when I add the Lt4 injectors and I thought about head studs but I think just using the ARP head bolts should handle my application with just 16 lbs of boost.
