Old 01-04-2018, 07:43 PM   #1
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Lifting the Rear End
Anyone know if it's possible to lift the back end of the car at the Rear Diff?
I'm thinking I can use a piece of 4x4 on a jack and lift just the ass end. I want to be able to rotate (spin, not swap) the back tires in my garage.
Old 01-04-2018, 07:54 PM   #2
WyGuy
Drives: 2017 ZL1 M6
Use the rear cradle as the lift point, not the diff.
WyGuy is offline   Reply With Quote
Old 01-04-2018, 08:00 PM   #3
kwav8r
Flyin NOE
Would love to but I'm using a floor jack, single lift point.
Unless I'm misunderstanding what you mean by "cradle"
Old 01-04-2018, 08:11 PM   #4
WyGuy
Drives: 2017 ZL1 M6
The rear cradle is the main structure in the rear that the suspension components tie into. It’s directly behind the diff, looks like an I-beam almost (painted black).
Old 01-04-2018, 08:14 PM   #5
kwav8r
Flyin NOE
Got it. I'll take a photo for the sake of the group.
Thank you!
Old 01-05-2018, 06:50 PM   #6
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Absolutely no problem lifting with the diff. I block of wood between the floor jack and the housing, raises just fine.
lt4camaro is offline   Reply With Quote
