![]() Drives: 2016 Camaro SS Join Date: Jul 2016
Do I need to reinforce shafts for ~800ish rwhp?
Hello,
My target is ~800ish rwhp with 93oct + meth and forged engine. I am wondering if I should change drive shaft and axle shaft for it. and furthermore, A8 mission. Frankly, my A8 seems got some little slip at gear changing. (rev is going up , down and up again slightly after changing gears, especially 5th and 6th gear changing) as I got 650 rwhp. Is there any way to reinforce A8? or just using the better oil? |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
The driveshaft and axles are more about how hard you launch it. I am around 750rwhp and running high 9’s but leaving a little soft and all that stuff is fine. I would say around a 1.5 60’ you will want to upgrade.
My a8 is stock and I have been told by a number of people about 800 is the safe limit of a stock a8. I am turning my car up this winter and going for 1000+. For that I was told to go with Steven at 42autosports. He told me they have a few cars pushing 1200rwhp. Cost is $2350. I don’t know what they do.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#3 | |
![]() Drives: 2017 Summit White 2SS A8 Join Date: Oct 2013
![]() Good info
Mod List: Stock (for now) |
![]() Drives: 2016 2SS Camaro Join Date: Apr 2014
My car is a little over 900 rwhp right now and I’ve made a handful of passes at that power level on stock axles cutting a pb of 1.35 but I did bend some of the driveshaft flange bolts
#5 | |
and to get to that hp # which are you doing meth, race fuel, or port injection on top of the LT4 fuel system?
Stock a8 besides circle d converter and I have direct port meth with 9th nozzle before throttle body and lt4 high side and low side and a secondary external low side pump triggered by boost
#7 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I can build it how you want it and ship it to you ready to rock. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
