01-02-2018, 05:39 PM | #1 |
Drives: 2017 Camaro 1LE Join Date: Mar 2017
18 inch wheel setup for the 6th gen 1LE
I am looking for a 18 inch wheel setup for my 1LE has anyone looked into the idea or know of anyone or company that has rims that fit the 6 piston.brake system. Any help would be great thank in advance.
01-02-2018, 05:46 PM | #2 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
There are 18 inch wheels that will fit over the brakes. The problem is inner clearance. Im assuming you are wanting to do something wide? If so, you will be limited.
01-02-2018, 09:15 PM | #3 |
Drives: 1LE Join Date: Dec 2016
+1 on the 18" wheels fitting over the brakes. Tire Rack will tell you exactly what fits in each width. I'm running 18" snow tires on all four corners.
01-05-2018, 02:43 PM | #4 |
Drives: 6mt Join Date: May 2017
I'm sure someone has a brake template for these. They should fit in the barrel of most 18" wheels but certainly not all. I believe any of the Apex ARC-8 or EC-7 18" wheels will clear the caliper but there's not much room. I ran them on a different car with 380mm front brakes and clearance was only 2-3mm. Prepare to cosmetically damage the calipers and wheel barrels in doing so because tiny pebbles and other road debris will get caught between the two and scratch both up. There's no getting around it.
01-05-2018, 02:49 PM | #5 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
01-05-2018, 04:09 PM | #6 |
Drives: 2018 2SS M6 Vert Join Date: Oct 2017
01-05-2018, 04:40 PM | #7 |
01-05-2018, 05:31 PM | #8 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
What does the et25 mean?
01-05-2018, 05:35 PM | #9 |
01-05-2018, 10:20 PM | #10 |
Drives: 2018 2SS 1LE Join Date: Oct 2017
So what do you guys suggests for 18' winter tires? After some research I found that no 18's radius perfectly matching that from the original 305/30/R20. I wonder how much tolerance can the car handle before ABS or traction control steps in? Tire rack suggests 275/40/R18 and 285/40/R18 for front/rear.
01-05-2018, 10:29 PM | #11 | |
01-06-2018, 12:19 AM | #12 |
01-06-2018, 10:46 AM | #13 |
Drives: 1LE Join Date: Sep 2017
18" APEX
Plenty of claipier clearance. 1/2" spacer and some mild clearancing needed on the strut. |
01-06-2018, 12:46 PM | #14 |
Drives: 2018 SS 1LE Join Date: Apr 2017
