Old 01-01-2018, 06:40 PM   #1
Zack46
Zack46's Avatar
Frozen Gas Tank, Any Suggestions?
I'm in cleveland, where its like -5 degrees outside. I pull up to the gas station to fill up my gas tank, and what do you know, i can't open the gas tank lid...It's frozen shut because of the extreme cold....I don't want to try to pry it open and risk scratching the hyper blue paint....
Any suggestions?
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 01-01-2018, 06:49 PM   #2
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Any suggestions?
Use this:
Old 01-01-2018, 06:50 PM   #3
Rhox
Rhox's Avatar
Drives: 2017 Camaro 2SS 50th Anniversary
move to florida. it's a little windy but not too bad.
2017 Camaro 2SS 50th Anniversary Edition | A8 | Borla S-Type Carbon Fiber Tips Axle-Back
Rhox is offline   Reply With Quote
Old 01-01-2018, 06:53 PM   #4
HyperBlue16
HyperBlue16's Avatar
Drives: 2016 Camaro RS
Poor warm water over the left most side and try to thaw the spring latch?
HyperBlue16 is offline   Reply With Quote
Old 01-01-2018, 06:55 PM   #5
Ryanbabz71
Ryanbabz71's Avatar
My shed lock was frozen today. I DO NOT suggest using my method i used to dethaw by using a propane torch. Worked great but using by a combustible (gas) would turn out bad.
Ryan
Old 01-01-2018, 07:04 PM   #6
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Try the window washer fluid to de-ice it. The alcohol is diluted enough to not hurt the paint. Good luck.
Old 01-01-2018, 08:27 PM   #7
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
Mine froze the other day too. I just pushed on the left side of the door till the ice cracked. Was then able to pry open the door and work the button till it freed up.
turbojeep95 is offline   Reply With Quote
Old 01-01-2018, 08:28 PM   #8
cjon9657
cjon9657's Avatar
Drives: 2017 2LT RS
Send a message via MSN to cjon9657
I had this happen to me today. I used a blow dryer, had it open within minutes.
cjon9657 is offline   Reply With Quote
Old 01-01-2018, 08:36 PM   #9
trophy hunter
trophy hunter's Avatar
Drives: 2016 1SS - M6
I agree.......
Go into the gas station and ask them for a cup, or purchase one to keep in the car. Use their rest room for the hot of water. At the car, gradually pour it over the latch area, testing it every so often......I use to live in Rochester, NY - so I feel your pain
trophy hunter is offline   Reply With Quote
Old 01-01-2018, 08:43 PM   #10
JeffFox
Drives: 2018 2SS Coupe A8
Here is a safe, easy, inexpensive solution
Any suggestions?
I would fill a baggie with hot water and hold the baggie against the fuel door until the the door opened freely. Do NOT pour the water on the car as it may freeze either now or during your next fill up attempt if the weather stays cold.This is very effective because of the high heat content of water. It is safe, cheap and risk free. Also a great way to thaw out frozen locks and door latches. It typically works in less than a minute but could be repeated until successful. Will not damage paint.
I would stay away from hair dryers, torches or other sources of heat. Most gas stations have hot water and plastic bags to easilly to replicate at the pump safely if needed.
Happy Motoring!
JeffFox is offline   Reply With Quote
Old 01-01-2018, 08:44 PM   #11
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
I remember my dad using a can of spray de-icer on frozen car door handles when I was a kid. The stuff worked great! It may have been windshield de-icer. Walmart sells a Prestone brand spray windshield de-icer that might work just as well.
STYLO LT1 is offline   Reply With Quote
Old 01-01-2018, 08:54 PM   #12
gippy87
Drives: 2016 2ss
On the bright side at least the door isnt locked. this happened several times on Jeep except the jeep has a locking door that is released by a button inside the car... No way to pry it open unless you have someone sitting there pushing the button. not fun.
gippy87 is offline   Reply With Quote
Old 01-01-2018, 10:19 PM   #13
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
Well this thread failed to deliver. I came to read about the frozen tank and what happened. Boo
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 01-01-2018, 11:11 PM   #14
Oldfart
Oldfart's Avatar
Drives: Silverado, V-70 R
I've had luck over the years with just giving it a light rap with the bottom of your fist. It often isn't held by much ice. I've done the same thing with pop-up headlights.
Oldfart is offline   Reply With Quote
