Old 12-31-2017, 11:26 AM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
ZL1 1LE Road coarse setup
So when I adjust my front camber to the track setting should I get an alignment as well? If so what are the alignment settings to use?
tnspd is offline   Reply With Quote
Old 12-31-2017, 11:40 AM   #2
djoker08
HTCC Member
djoker08's Avatar
Drives: 2018 ZL1 1LE HBM
I had mine checked and adjusted in the track camber setting. It was at -3.1 left -2.9 right and it adjusted to -2.7 front and -2.0 rear. I would definitely have it checked while on the track camber, not sure if others were off like mine camber was.
djoker08 is offline   Reply With Quote
Old 12-31-2017, 11:45 AM   #3
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I would definitely check both camber and toe before you hit the track.
seanblurr is offline   Reply With Quote
Old 12-31-2017, 11:47 AM   #4
tnspd
tnspd's Avatar
what should the toe be set at?
