RedLine
New Street wheels and tires for ZL1 1LE W/pics
So I am one of the Crazies that will track and daily my ZL1 1LE. (on the nice days) so I knew going in to this I would require a second set of wheels and tires for the street. I'm not a bling guy I don't spend big bucks on wheels that I will be driving on the street so I was looking for "cheap" options.
Haters don't Hate... Yes I put cheap wheels on my ZL1. My wife also drives it and if a wheel gets curbed bent or cracked I want to be able to just replace it and move on. So if your looking for a cheap good looking set up for the street here it is... The Wheels https://www.nlmotoring.com/XXR-530-W...f-10%2E75=1694 The Tires https://www.tirerack.com/tires/tires...omCompare1=yes ![]() ![]() ![]() ![]() ![]() ![]() Wheels XXR 530 19 x 10.75 +35 offset Rear and +15 Front. 325/30R19 on all four corners. The Firestone's give very good wet/cold traction and solid hot/dry traction. I had this set up on my 13 ZL1 and the fronts poked out a bit. But on the New ZL1 with the wider fenders they fit perfect. I will say the tires come extremely close to the height adjusting collar on the front strut. If you shop deals you can find this set up for $1600-$1700 Last edited by tomster; 12-30-2017 at 01:14 PM. |
![]() Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
I like them, do you have anymore pics of the rears installed?
RedLine
Same wheels on my 13 ZL1 but in flat and with 305/30R19 tires
RedLine
RedLine
Thanks, they look great.
#7 |
![]() Drives: 2013 Cayenne GTS Join Date: Dec 2013
Why did you not go 305 front and 325 rear and use original tires?
#8 | |
![]() Drives: 17 Hyper Blue SS 1LE Join Date: Aug 2017
#9 | |
![]() Drives: 2015 Ultimate Track SS Join Date: Apr 2015
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/ 2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD 2010 2SS/RS M6 -- SOLD |
#10 |
RedLine
your right I fixed the first post
#11 | |||
RedLine
Sorry your right "15mm front 35mm rear" Quote:
I was looking to get just a little more height in the front for "street use" The original tires will be used for track use until worn, then I will switch to slicks on the OE wheels. Plus the Firestones run slightly narrower than the Goodyears that came on the car. (as if its a 315) and i like the look of a nice FAT tire on all 4 corners. |
#12 |
RedLine
Firestone specs
325/30R19 101W SL 340 A A 1,819 lbs. 51 psi 10/32" 33 lbs. 11.4"TW 26.7"OD Goodyear Specs 325/30ZR19 (101Y) SL 100 AA A 1,819 lbs. 51 psi 5/32" 31 lbs. 12.5"TW 26.7"OD Goodyear Specs 305/30ZR19 (98Y) SL 100 AA A 1,653 lbs. 51 psi 5/32" 29 lbs. 11.8"TW 26.3"OD According to the spec the firestone 325 is actually narrower then the Goodyear 305. However side by side the look the same. This is why I went 325 all around. Plus it raised the front about a 1/4 inch to help with Inclines . Don't get me wrong I cant wait to get the OE wheels with the Sticky Goodyears on track to see what they can do but unless its 90 degrees and your on a perfect road you will never explore what the Goodyear is made of on the street. It is a Track Tire designed for track use. Why would you want to waist it driving it on the street? |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
nice setup...my kind of logic with the wheel/tire combo
#14 |
![]() Drives: 2018 ZL1 M6 Join Date: Dec 2017
