Old 12-28-2017, 03:27 PM   #1
BMGR1
BMGR1's Avatar
Drives: 17' SS 1LE
Hanging RPM's ???
So I recently swapped out my stock Intake manifold for an MSD Airforce Intake manifold.
Install went smooth and got everything tightened up..... Now I have a very small issue... Sometimes when I let off the gas, the RPM's hang in the same spot for a couple of seconds and the slowly decline (happens 1 out of 10 times).... or when I go into neutral and coast to a stop, the RPM's hang for a few seconds....
I was thinking it might be the fact that I'm possibly running lean due to all the mods my car has and hasn't been tuned yet. It could also mean a vacuum leak, but my car hasn't thrown any codes for it.
-RotoFab CAI w/Oiled Filter
-Katech Ported TB
-MSD Intake Manifold
-CA Performance Test Pipes
-Stainless Works Catback Exhaust
Any ideas on what it could be?
2017 SS 1LE Texas Speed 1 7/8" Longtubes | MSD Atomic Airforce IM | Stainless Works Catback w/NPP | Katech Ported TB | RotoFab CAI | E85 (475hp / 476tq)
2015 R1
2003 350z
BMGR1 is offline   Reply With Quote
Old 12-29-2017, 12:31 PM   #2
Racer Ed
Drives: 2016 Camaro 2 SS
-Katech Ported TB
My 16 SS does exact same thing, I also have a Katech PTB. W/ stock Intake.
May want to put the Stock TB back on and see if it Fixes it.Hope you can find
the problem.I had my car Dyno Tuned and nothing showed up wrong ???
I will be getting a Pray PTB and Intake soon.
Ed
Racer Ed is offline   Reply With Quote
Old 12-29-2017, 01:15 PM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
i'm nearly full bolt ons and tuned on e85, i still have insane rev hang, don't really think their is much that can be done to be honest.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 12-29-2017, 03:42 PM   #4
AchiliesSS
AchiliesSS's Avatar
Drives: 2017 Black on Black 1SS
Hey guys, I have had the issue since I had my car new, it happens here and there and my car is completely stock. I believe its just a fault in the design or tune, nothing wrong with your car.
AchiliesSS is offline   Reply With Quote
Old 12-29-2017, 04:22 PM   #5
Spartan268
Spartan268's Avatar
Drives: HB 2SS
-Katech Ported TB
I saw another poster in the general section saying something about loose bolts on the intake and a leak. It didn't throw any codes but half the bolts were missing and some others were loose. There's something in the MSD instructions to tighten again after 1000 miles.
Spartan268 is offline   Reply With Quote
Old 12-29-2017, 05:16 PM   #6
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
I'm not modded, but this sounds a lot like what happens when you try to rev the engine during the cold start cycle. Is it like that?
Oil Man is offline   Reply With Quote
Old 12-29-2017, 05:49 PM   #7
Spartan268
Spartan268's Avatar
Drives: HB 2SS
I believe it's something like this:
https://youtu.be/dHEp5YE2tC4?t=4m20s
Old 12-29-2017, 06:33 PM   #8
SSDanny
Drives: 2017 Camaro SS M6
I believe the cars stock tune does this because of emissions. It sucks, but that's what happens with these electric throttle bodies..
A tuner should be able to tune this out according to another member on here.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
Old 12-29-2017, 07:35 PM   #9
Oil Man
Oil Man's Avatar
Wow. Ok. That's a more extreme example of what I was thinking of.
Old 12-29-2017, 08:21 PM   #10
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I know exactly what it is. It’s a vacuum leak in your manifold.
When I changed over to my Holley high ram, I had a vacuum leak and it sound exactly like the YouTube video that was posted above. I redid my gasket and tighten down the bolts and it was fine.
If you have not modded, then simply check for a vacuum leak with stock intake manifold.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 12-30-2017, 11:21 PM   #11
BMGR1
BMGR1's Avatar
Drives: 17' SS 1LE
FIXED!!
It was a vacuum leak at the manifold intake runners.... the 10 outer bolts of my MSD manifold became loose probably from all the vibration and the fact that I didn't use threadlocker on the bolts and was causing a vacuum leak as stated above....
I bought some blue loctite and applied to all the supplied bolts, all good now... Check your manifolds or throttle body bolts to make sure they are tight after 2-3 heat cycles.... It only took my MSD IM bolts 3-4 days to come loose to the point I could undo them by hand
Hope this helps some of y'all
2015 R1
2003 350z
Old 01-02-2018, 10:14 AM   #12
01midmetws6
01midmetws6's Avatar
Drives: 16 Camaro 1SS A8
There is also an updated GM calibration file to address hanging idle issues on stock cars. We use the updated cal file on all 6th Gens before tuning to eliminate this issue. The TSB number is #16-NA-074:
01midmetws6 is offline   Reply With Quote
