Old 12-27-2017, 09:45 AM   #1
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Fan Blowing Before Startup
First start of the day when I open my drivers door to get in I hear what sounds like a fan blowing for a second or two. The fan sounds like it could be a seat cooling fan but this is a 1SS 1LE.
Any ideas?
Gabhart is offline   Reply With Quote
Old 12-27-2017, 12:34 PM   #2
blackss1le
blackss1le's Avatar
Drives: 2017 Black/ Black SS 1Le
Any ideas?
That's crazy.
I've seen another thread a few weeks ago about the 1LE does have the fan installed under the seats, just not connected with power. It's like they put the same seats in the 1LE as the 2SS, just didn't wire up with option to use them. It would be nice to use them. Some were trying to figure out how to use them.
Sent from my SS Note8 1le using Tapatalk
blackss1le is offline   Reply With Quote
Old 12-27-2017, 01:36 PM   #3
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
The 1LE Recaros are a bit different than the 2SS leather covered version of the 1SS seats.
Old 12-27-2017, 02:03 PM   #4
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Is it the humming/buzzing noise from the headlights you are hearing?
CruzySS is offline   Reply With Quote
Old 12-27-2017, 02:37 PM   #5
blackss1le
blackss1le's Avatar
Any ideas?
Look here
http://www.camaro5.com/forums/showthread.php?t=490124
Old 12-28-2017, 12:09 AM   #6
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
I hear it too it's not from the seat but sounds like its from behind the dash some computer full speed fan check.
thescreensavers is offline   Reply With Quote
Old 12-28-2017, 06:52 AM   #7
Gabhart
Gabhart's Avatar
No, it's definitely in the cabin
Old 12-28-2017, 06:54 AM   #8
Gabhart
Gabhart's Avatar
That's most likely what it is. I know there is a module under the glovebox that has a fan.
Old 12-28-2017, 06:56 AM   #9
Gabhart
Gabhart's Avatar
Originally Posted by blackss1le View Post
Look here
Read thru this one a while back. Thing is if I do have fans in my seats they should not have power to them. All depends on the time and day it was built I guess!
Old 12-28-2017, 07:45 PM   #10
Printman
Printman's Avatar
Drives: 2018 Camaro SS 1LE
My hearing is not good so take this for what it is worth. What I hear when I open the door is like a fuel pump priming the line sound. Someone with more knowledge about the LT1 will have to chime in to confirm.
Printman is offline   Reply With Quote
Old 12-28-2017, 08:58 PM   #11
ajr6thgen
ajr6thgen's Avatar
Drives: Arctic Blue '18 1SS 1LE
I hear the same thing when I open my door. I also thought it was fuel pump priming or maybe the shocks initializing (have no idea how they work). But don’t see the car height change at all. (Self leveling ?) ideas anybody?
ajr6thgen is offline   Reply With Quote
Old 12-28-2017, 09:18 PM   #12
WhyUMad1LE
Drives: 17 SS 1LE
I always thought that was the MyLink system starting up, it sounds like the cooling fan from a computer.
Old 02-27-2018, 12:54 AM   #13
Bigdome77
Im almost sure it is the fuel pump, for me it only happens when the car sits overnight which would give the fuel plenty of time to return to the tank.
Bigdome77 is offline   Reply With Quote
Old 02-27-2018, 06:48 AM   #14
Gabhart
Gabhart's Avatar
I do hear the fuel pump. The sound I am asking about is definitely a fan coming on then shutting off almost immediately. The infotainment system fan is the most likely suspect.
