Old 12-25-2017, 02:30 PM   #1
Soleil
Soleil's Avatar
TSB / SB preliminarily Information
Here is a list with TSB’s and preliminary Information.
The list will be updated from time to time.
Recalls
- Recall Bulletin 15808B No Key in Reminder Chime
Recall 573 Report-Amendment 1
Service Bulletins Information
Airbag
- SB-16-NA-246 Information on Airbag Warning Lamp Illuminated
Infotainment System/Navigation/Radio
- SB-16-NA-138 OnStar Diagnostic Alerts Sent When Vehicle is Being Serviced
- SB-PIC4707E XM Weather, Traffic, or Travel Link Displaying Dashes, NO DATA or UPDATING Message At Startup
- SB-PIC4935E Subject: Normal Characteristic - OnStar Power Consumption
- SB-PIC5088F XM Band Not Receiving All Channels
- SB-PIC5374D Off Route Message During OnStar Turn By Turn Operation
- SB-PIC6095A Part Identification For Next Generation Infotainment Components
- SB-PIC6170 Vehicle Position Indicator Showing Incorrect Location After Making A Turn
- SB-PIC6171A Radio Display Unresponsive or Makes Random Selections with No User Input
- SB-PIC6177A Navigation Radio Destination State Defaults To WV Instead of VA On Manual Entry Only
- SB-PIC6186B Radio turns on unwanted at startup
- SB-PIC6187A USB Or SD Favorites Gray Out And Inoperative When Selected Intermittently
- SB-PIC6193B Cannot Save XM Favorites
- SB-PIC6197 Diagnostic Aid-Phone Will Not Connect To Android Auto
- SB-PIC6201 Wi-Fi Or Bluetooth Inoperative Or Poor Performance
- SB-PIC6205 Phone Icon On Radio Display Intermittently Will Not Respond Or Spins When Pressed
- SB-PIC6216 Voice Command For Calling Bluetooth Phone Contacts Inoperative
- SB-PIC6218 HVAC Pop-Up On Radio Display Blank Intermittently
- SB-PIC6219 Blank Radio Display
- SB-PIC6220 Intermittent loss of gridlines in the rear camera display screen
- SB-PIC6221 Intermittent No XM Audio Or No Signal
- SB-PIT5384B Gen10 OnStar WIFI Inoperative Or WIFI Connection Concerns
- SB-PIT5389A Gen10 OnStar Unable To Connect Or Connects Failed To Voice
- SB-PIT5401F Radio Inoperative with No Communication and DTC U0184
Tires/Wheels
- SB-13-03-10-001D Information on Tire Cold Weather Cracking
- SB-PI1498B Clicking Noise from Front and/or Rear Wheels
Engine
- SB-00-06-01-012F Use of "Surface Conditioning Disks" When Cleaning Engine Gasket Sealing Surfaces and/or Reused Engine Parts
-SB-16-NA-129 Crankshaft Balancer Wobble or Vibration Appearance
- SB-07-06-01-016C Information on Internal Engine Noise or Damage After Oil Filter Replacement
- SB-PIP5130G Engine Runs With Intermittent Crank No Start With P0011 Or P00C6 May be Current Or Set In History
- SB-PIP5159B Engine Misfire May Be Due To loose Spark Plug Wires
- SB-PIP5168E Crank No Start - Inspect for Sheared Cam Pin
- SB-PIP5189B Black Smoke On Cold Start
- SB-PIP5226A Needle Bearings Found in the oil pan During An Oil Change
- SB-PIP5230C SI Diagnostics Determines The Engine Repair requires Crankshaft Replacement
-SB-PIP5248B Stalling Shudder And/or Hard shifting Into 1st Gear Or Reverse Vibration On launch (With Excessive Crankshaft End Play)
- SB-PIP5282A Engine Oil Life Monitor Operation Calculation
- SB-PIP4786C Low Oil Pressure Message/Light - Inspect Valve Lifter Oil Filter
- SB-PIP5354 Spark From Harmonic Balancer
- SB-PIP5374 Subject: Loss Of Oil Pressure On LT1 Camaro Only
- SB-PIP5379 RPM May Hang High After The Throttle Is Snapped
- SB-PIP5401 Light Tap Or Knock Noise From Engine When Hot
- SB-PIP5405A Surge Misfire Feeling Sensation During Highway Steady State Driving
- SB-PIP5407 Code P06DD No Or Low Oil Pressure
- SB-06-06-05-001G Information on Changes in Exhaust Tone for Active Fuel Management Engines When in Three or Four Cylinder Mode
- SB-PIP5361 High Pressure Fuel System Codes
Power Train
- SB #2052620 Transmission Oil Cooler Line
- SB-03-07-29-004K Manual Transmission Operating Characteristics
- SB-16-NA-019 Information on Transmission Adaptive Functions and Correcting Low Mileage Harsh Shifts, Slips, or Flares
- SB-16-NA-117 Information Regarding Magnetic Drain Plugs
- SB-PIP5375A Rear Wheel Drive Manual Transmission Restriction
Batterie
- SB-03-06-03-004R Battery Testing and Warranty Replacement Requirements (North America ONLY)
- SB-15-06-03-001B Cold Weather and Long Stand Time Battery Maintenance and Testing Tips
Electrical/Windows
- SB-06-08-47-001L Warranty, SPS, Control Module Diagnostics and Configuration Information, Programming, Set-Up
- SB-16-NA-272 Information on Vehicle Time Out for Parasitic Draw Testing
- SB-PI0754B Rear and Side Tempered Glass Spots (Quench Marks)
- SB-PIC5260A Intermittent Sunroof Operation, Bind, Noise, Auto-reverse, and/or Water Leaks
- SB-PIC6160A Water Intrusion - Forward Lamp Harness - Engine Cooling Fan Inoperative - DTC P0480
- SB-PIC6189 Wind Or Buffeting Noise While Driving With One Window Lowered
- SB-PIE0369 SES Light On with One or More DTCs Set
- SB-PIP5306C PQC Part Restriction - E82 ECM Restriction Part Number 12659039
- SB-PIP5373A Program ECM Error E4491/E4423
- SB-PIP5386A MIL Illuminated With DTC's P0264 Or P0265 and P0300 Set
- SB-PIP5395A Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment
- SB-PIP5423 SES lamp with a P0106 and P0506
- SB-PIP5425A Illuminated MIL DTC P0747 Or P0796 May Be Set As An Active Or History Code In The TCM
- SB-PIT4720D Odometer Servicing When The Odometer Cannot Be Set To The Actual Mileage
Structure
- SB-10-08-110-001E Information on Proper Use of Floor Mats
- SB-PI0281E Underbody Component Corrosion
- SB-PI0388F Seat Belt Webbing/Latch Plate Becomes Twisted
- SB-PIC6276 Clunk Noise From Front Suspension
TSB
- 44470 Torque Converter THIS PROGRAM IS IN EFFECT UNTIL JUNE 30. 2018
- TSB #10-08-46-001C Radio Does Not Mute Enough When OnStar® Turn-by Turn Navigation Directions Are Announced
- TSB #11-08-49-001S Transport Mode On Message Displayed in DIC
- TSB #15-06-01-002C Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) On, DTC P0300 Set
- TSB #16-NA-005 Subject: Power Seatback Stuck in Full Forward/Rearward Position
- TSB#16-NA-014 Delayed Engagement After Sitting With Engine Off
- TSB #16-NA-042 Infotainment System Upgrade for Android Auto Feature
- TSB #16-NA-043 Accessory Wheels Unable to Learn Tire Pressure Indicator Sensors
- TSB #16-NA-043 Tire Pressure Monitor (TPM) Concerns After Accessory Wheel Installation
- TSB #16-NA-078 Rattle Noise from Manual Transmission Shifter
- TSB #16-NA-107 Subject: DTC U0184 Set, Radio Inoperative, Blue Screen, AM Clipping Noise, HD On/Off Status Not Retained in Stations, Time Lag on Transitions, No Audio with Internal Amp, Park Assist Symbol Position Wrong in Rear View Camera
- TSB #16-NA-108 Buzz or Static Noise from Radio Audio Speakers
- TSB #16-NA-109 Grease or Sealant Visible on Electronic Power Steering Gear - Should Not Be Interpreted as Leak
- TSB #16-NA-111 Diagnostic Tip for Malfunction Indicator Light (MIL) Illuminated, DTC P0420 and P0430 Set
- TSB #16-NA-124 Spare Key Not Fully Retained in Remote and/or Remote Button Not Fully Released
- TSB #16-NA-139 Active Noise Cancellation (ANC) Boom Noise Heard 900–1100 RPM
- TSB #16-NA-173 Exhaust Rattle Noise Originating from Rear of Vehicle
- TSB #16-NA-175 Shake or Shudder During Light Throttle Acceleration
- TSB #16-NA-194 Check Engine Light Illuminated After Using Manual Paddle Shift
- TSB #16-NA-210 Lack of Power on Hard Acceleration
- TSB #16-NA-219 GPS Inoperative, Red Line Across GPS Indicator or the Location is Stuck in Warren Michigan
- TSB #16-NA-239 Information on Enabling 4G LTE Wi-Fi Hotspot on New Vehicle
- TSB #16-NA-241 Engine Misfire, Ticking/Knocking Noise, No Compression due to Piston Damage, Malfunction Indicator Lamp (MIL) Illuminated
- TSB #16-NA-242 Diagnostic Tips for USB Receptacle Inoperative
- TSB #16-NA-255 Damage to Matte Black Decal on Rear Compartment Lid When Installing Black or Illuminated Bow Tie Kit
- TSB #16-NA-257 Top Not Secure Message Displayed on DIC
- TSB #16-NA-259 Rattle Noise from Front Seat Back Easy Entry Release Handle
- TSB #16-NA-396 Intermitted Operation of Key Fob
- TSB #17-NA-039 Information On Engine Oil Requirements for LTG 2.0L
- TSB #17-NA-115 Intermittent Vehicle Pulls While Driving
- TSB #17-NA-142 Wireless Charging Module Diagnosis
- TSB #17-NA-271 Clunk Noise from Front Wheels While Turning at Slow Speeds
- TSB #17-NA-259 Body Creak Noise from Rear Seat Area
File Type: pdf TSB #17-NA-259 Body Creak Noise from rear Seat.pdf (7.35 MB, 821 views)
Soleil
Old 12-25-2017, 03:18 PM   #2
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
Proper use of floor mats? Are some people using them as engine covers?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 12-25-2017, 03:37 PM   #3
Soleil
Soleil's Avatar
Just to make sure.
Soleil
Old 12-25-2017, 11:39 PM   #4
Opus13
Opus13
Opus13's Avatar
Drives: 2017 Camaro 1SS, Black
I actually downloaded it just to see what it stated.
"My entire life in one sentence:
It didn't go as hoped, but that's okay"
Opus ie. Berkeley Breathed.
Opus13 is offline   Reply With Quote
Old 12-28-2017, 07:31 AM   #5
CCS71
LFX to LT1
CCS71's Avatar
Drives: 2017 Camaro Fifty 2SS M6
Following.
2013 Rally Yellow 1LT - Traded
2017 Camaro Fifty 2SS; Sequence #270 - Sunroof/Nav/NPP/MRC/6speed
CCS71 is offline   Reply With Quote
Old 12-28-2017, 02:35 PM   #6
SSJ455
SSJ455's Avatar
Originally Posted by Soleil View Post
I guess there are those people out there who don't have a clue. That is why there are warnings on shampoo bottles saying for external use only.
What?
Dangerzoooooone.
Old 01-26-2018, 10:29 PM   #7
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Subscribed for reference.
Unbelievable, when $50+K is paid for a new vehicle,
This is absolutely unacceptable. I would walk if an ordered new car was intended to be delivered in the conditions that are deemed "acceptable" in TSB/SB PI0281E. See pics in link.
2018 ZL1 1LE sw/PDR
Old 01-26-2018, 10:40 PM   #8
travislambert
travislambert's Avatar
Drives: '17 ZL1
Yep... Totally agree.
GM better wake up on this and realize people care about the cosmetics. The days of vehicles being purely for transportation are long gone.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 02-02-2018, 09:28 PM   #9
enzia35
Drives: '16 Garnet Red 1SS
Thank you for this thread! I'm going to see what needs to be done before warranty is up...
'16 Camaro 1SS
'18 Miata GT
Old 02-27-2018, 01:32 PM   #10
Jfmoore79
Jfmoore79's Avatar
Drives: 2016 Garnet Red 2SS A8
Is there a TSB or Corporate Bulletin addressing the chatter from the limited slip diff? I have seen it mentioned in articles but could not find anything "official".
Jfmoore79 is offline   Reply With Quote
Old 07-26-2018, 04:09 PM   #11
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
#18-NA-137 formally PIP5234C Fuel injector Seal Replacement
I am not sure where to add this data, but wanted people to know about it and be aware. I personally just experienced this one. 2018 ZL1 A10
more information here
https://www.camaro6.com/forums/showt...6#post10263236
TLSTWIN is offline   Reply With Quote
Old 07-27-2018, 02:52 PM   #12
enzia35
Probably good idea to add 16-NA-399.
https://www.cadillacforums.com/forum...formation.html
'16 Camaro 1SS
'18 Miata GT
Old 04-21-2019, 09:55 AM   #13
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
TSB-18-NA-355
Another on the A8 shudder.
mdhopt36 is offline   Reply With Quote
Old 07-01-2019, 12:51 PM   #14
Yellow BB
Yellow BB's Avatar
Drives: 2017 Camaro SS 2SS
Where is the Safety Recall N182182760 “Loss of Electric Power Steering Assist While Driving” for 2017 Chevrolet Camaro A vehicles?
Yellow BB is offline   Reply With Quote
