Old 12-20-2017, 11:04 AM   #1
parish8
Drives: 17 SS a8
Low budget high hp motor build? I BROKE IT!
i am looking at doing the drop in rods and piston set up and plan on cranking it up over 1000hp. Here is the minimum plans.
Rod and piston kit
Cam, dod delete kit, springs, phase lock or limiter
Head studs
That’s about $4k. What am I missing? Patrick g is going to spec out a cam for me. It will have the 32% fuel lobe.
Are the lt4 head gaskets any better and do they work on an lt1? Do the valves in the heads need upgraded? Should I do main studs and can you just bolt them in without any machine work?
Old 12-20-2017, 11:41 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Rod and piston kit
Head studs
Machine work is a must to fit all the parts together.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-20-2017, 11:56 AM   #3
parish8
Drives: 17 SS a8
After doing some research it looks like the main studs would require machine work so they are out.
The drop in piston and rod combo isn’t suppose to need anything but a light hone and file fit the rings. I can do that stuff in my garage.
Old 12-20-2017, 12:12 PM   #4
Redlinez
Shifts under load
Redlinez's Avatar
Wow, PatrickG is still at it!
22 Suzuki GSX-S 1000GT blue
Old 12-20-2017, 12:25 PM   #5
JANNETTYRACING
I mean no disrespect when I say this, this is no Briggs and Straton.
Don't get caught up in the sales pitch for a 1000 HP combo stuff needs to be done right.
A Torque plate hone to set piston to wall clearance is required.
Blueprint and balancing is required as well.
Ted.
Old 12-20-2017, 12:35 PM   #6
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Ted.
No disrespect, but there are a few guys well over 950 to the tire with just a light ball hone and drop in rods and pistons (Cunningham Motorsports set up)
Perdieu is offline   Reply With Quote
Old 12-20-2017, 12:40 PM   #7
JANNETTYRACING
Non taken.
I take the position, just because someone else gets away with it doesn't make it right.
If I am going to break and engine down it is going to get a blueprint and balance job even it I don't change any parts. NHRA stocker tricks.
Ted.
Old 12-20-2017, 12:55 PM   #8
parish8
Drives: 17 SS a8
I will be sure and let everyone know how it does. Plan is to turn it strait to 1000rwhp and work up from there over time.
Anyone else have any other suggestions i might want to consider while it is out?
I am getting the 42 auto sports trans upgrade.
Old 12-20-2017, 01:47 PM   #9
JANNETTYRACING
You may want to do that ARP hardware
Old 12-22-2017, 08:44 PM   #10
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Hey Parish8, I'm pretty sure that you have seen my thread. I used the CMS drop in parts. My motor had 6kish miles at teardown and the factory crosshatch as still visible. I did not do ARP main studs. But I do have ARP headstuds. Not sure what power the car makes. Should be right about 1000(crank). So far so good. While I drive it EVERY DAY I do not rev it beyond 6800.
Turbo_RORO is offline   Reply With Quote
Old 12-23-2017, 09:16 PM   #11
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
do you know if you can pull heads on and off with the motor in the car and head studs installed?
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 12-24-2017, 07:49 AM   #12
DFW1LE
DFW1LE's Avatar
Curious about LT-4 head gaskets vs LT-1. I believe the LT-4 are a thicker multi-layer design, so for a blown application, I would think you would want LT-4 gaskets.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 12-24-2017, 11:03 PM   #13
Turbo_RORO
Turbo_RORO's Avatar
I don't think that you can pull the heads with head studs in the car.
Old 12-24-2017, 11:05 PM   #14
Turbo_RORO
Turbo_RORO's Avatar
I do not think they are interchangeable. There is a issue that I cant remember right now. I also believe they are the same thickness. Also the head stud kit is different for LT1 to LT4. I think the difference is in the bolts. I think the LT4 has more bead bolts.
