Old 12-16-2017, 06:59 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
408 maggie 10 rib belt slip?
Its belt slipping on the dyno at 16psi at 4800 rpm down to 8psi. Im assuming i didnt tighten the hd tensioner tight enough? That was told to me by the tuner. Im sure he tighten it but i haven't heard nothing beside that. Im sooooo nervous
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 12-17-2017, 12:49 AM   #2
toohighpsi
Drives: 2015 C7 Z06 M7
What upper/lower pulley size are you using? Belt systems work perfect on these cars as long as the belt isn't too long. Since it sounds like you're probably running a smaller blower pulley so you might not have the right belt on there...
Old 12-17-2017, 03:31 AM   #3
hou30guy
2.9 upper and ati 6% od lower
Old 12-17-2017, 03:34 AM   #4
hou30guy
Belt number 10pk2425
Old 12-17-2017, 03:39 AM   #5
hou30guy
Is there a belt chart for these maggies and or camaro
Old 12-17-2017, 05:26 AM   #6
laynlo15
Drives: 2022 Lt1 A10
So is the 2.9 about 73mm pulley
Old 12-17-2017, 06:42 AM   #7
hou30guy
Ok so do i have the right belt
Old 12-17-2017, 06:44 AM   #8
hou30guy
I bought the supercharger set up used only thing different is my balancer is ati 6% od and his was innovative west which was 8 or 10% od. Everything else was the same
