![]() Drives: 2016 Mosaic Black SS 6M Join Date: Dec 2016
Annoying dash rattle
So I love my car! She’s been a blast, other than this annoying dash rattle (and the wind noise caused by mirror).
I know it’s a long shot... but the dash vibration noise seems to be somewhere in the driver section, behind the steering wheel. Anyone have similar experiences, or guesses? |
![]() Drives: 2017 2SS Join Date: Apr 2016
The chrome surround of the air vent at the farthest left side of the dash. Check to see if you can wiggle it. I found mine to be quite loose, causing a very audible vibration. However, it is not always loose and vibrating. It seems to vary a lot with temperature. I'm afraid to have the dealer look at it because I do not want them hacking into my dash. :(
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
There was a recent thread about a rattle from the trim around the radio. I have that - haven't had a chance to put some foam tape behind it, but if I put a finger on the trim going over rumble strips the rattle stops.
Good to know thank you both
![]() Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
I had one that seemed to be low & behind the dash. Dealer couldn’t find it and wanted to rip into the dash to troubleshoot. I said no thanks, didn’t want the mess that would turn into. Instead I got underneath the car and within 5 minutes I found the offending piece. The aluminum (fuel?) tubes were lightly rattling against the frame up near the motor mount. A zip tie to move them over a fraction of an inch took care of it.
#6 | |
![]() Drives: 2017 2LT RS Join Date: Oct 2017
I have what sounds like a bouncing plastic clip or maybe a wire harness, somewhere between the steering column and the left most AC vent, and it isn't surface level... its driving me nuts, and so far I haven't had any luck finding the source
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I have one on the bit of plastic right under the windshield, above the driver side vent.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#8 |
![]() Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Mosaicblackss- I too have that same exact noise your referring to in the same location.
Been scratching my head for months trying to pinpoint what exactly it is though. 16’ mosaic black SS vert. M6.
#9 | |
#10 |
![]() Drives: 2016 NGM Camaro 2SS Join Date: Apr 2016
I had an annoying rattle in the dash of my 2SS when accelerating and had it back to the dealer numerous times asking them to look at it. They eventually changed the exhaust on spec but that didn't help. They then thought it was the fuel lines hitting the frame and did a fix from a GM bulletin, but that didn't help either. I didn't want them to take a part the dash but I really hate rattles.
I landed up taking the Camaro to a different dealer for an oil change because my regular dealer couldn't fit me in when I had a day off. I mentioned the rattle but didn't expect them to have time to investigate. They found a bulletin saying that bolts on the shift linkage (have 6M) may come loose causing a rattle. They tightened the bolts and that eliminated the rattle. What I thought was a rattle in the dash was actually in the center console, go figure. Now all I hear when accelerating is the amazing sound of the engine/exhaust. Bulletin 16-NA-078
2016 NGM Camaro 2SS
2016 Porsche Macan 2015 Jeep Wrangler 1991 Acura NSX Last edited by caveman01; 12-15-2017 at 07:01 PM. Reason: add bulletin number |
#11 |
![]() Drives: Submarine Join Date: Nov 2016
Yes, the air vent on the left made noises. It was not that loose, its just the types of material in contact made some type of noise. I fixed it by just spraying some 303 vinyl protectant that soften it up a little.
We have to just face it. This is a nice looking car with a powerful drive train but cheaply made interior and exterior. Poor quality control to keep costs down. The left rear speaker area makes some noises. Mine is a convertible. A rattle noise comes from rear passenger side that I have finally tracked after weeks of looking for the source. I am afraid this will be a cancer. As the car gets older the noises will grow. It will be an ongoing battle. |
#12 |
I was finally able to isolate and fix the rattle noise I was hearing in my dash!
My rattle was actually coming from the hood release cable and/or one of the clips holding the cable to the body, under the hood. I taped it up with a couple strips of harness/fabric tape to hold it down tighter, and the rattle is no longer present! I am so happy and relieved to have it fixed. Sorry to resurrect a semi-old thread, but I wanted to post an update in case anyone else was having a similar issue. Look under your hood along the driver side and see if the cable or clips are loose. |
#13 |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
Nice and congrats! They can be annoying
I'm going to buy a louder exhaust haha
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
#14 |
![]() Drives: '17 2SS 50th Join Date: Sep 2016
Mine is somewhere near the glove box.
The rattle disappears when I open the compartment but comes back as soon as I close it. Tried foam, sound deadener and applied it around the contacting surface... still there. It’s so annoying I smash the box several times during my commute. Been fighting for a couple of months now. Ugh.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
