Old 12-10-2017, 11:44 AM   #1
NowaChevyGuy
NowaChevyGuy's Avatar
Drives: 2016 Camaro LT1 RS Black on Black
Custom painting your engine cover and other pieces - The details
Hi all,
So I decided to paint my own engine cover and fuse box lid and documented all the little in's and out's if anyone needed. This took way longer then I planned with work and life but I finally finished it off and am so happy I did it. Hope this helps if anyone is looking to do this yourself.
Subject: 2016 RS
Material Used:
Adhesion promoter
Duplicolor primer
Duplicolor engine enamel black
Duplicolor engine enamel clear
Duplicolor chrome
Duplicolor metallic blue
Rustoleum copper metallic
Various airbrush colors by spazsticks (had for RC hobby)
Lots of painters tape
Rubbing alcohol
Q tips
Rags/Paper Towels
Dinner for two to make nice nice with the wife for over spraying the porch blue (a little).
1.Pulled the cover and fuse box lid and removed rubber oil cap ring and hex bolt rubber grommet (see pics). This just pops out, don't be skeerd of it.
2. Sanded with 400 grit sand paper to rough it up. I used an old PC mouse as a sanding block (wrap sand paper around a block of wood or something, makes it easier.
3. Taped off outer area.
4. Sprayed adhesion promoter - waited 6 minutes. Second layer adhesion promoter - waited 12 minutes
5. Sprayed 2 coats primer - waited 12 minutes between and after
6. Sprayed inner area with copper - 3 coats 12-15 minutes between each coat.
7. Laid shelf liner from Bed Bath and Beyond over copper and sprayed black to create carbon fiber look.
8. Jacked up black CF look - Sprayed layer of copper and did again. Dry 15 minutes.
9. Wipe down with rag and alcohol to remove spray dust then sprayed with Clear - dry overnight.
10. Pulled outer tape and taped up now painted inside. Keep a single layer of tape and overlap the seem, then follow with a sharp exacto to easily trim clean lines.
11. Removed Bowtie dome (see pics). Used grinder to flatten out dome for new badge (Pain.... In.... The.... Ass....). NOTE- This is held on by a foam type adhesive and pressed on. At the bottom find a notch you can get under it and pry it up and off, or do like and jack it all up thinking it was way thicker than the thin tin material it is. If not changing it out, tape it up and be happy.
12. Rinse and repeat. 2 coats adhesion promoter, 2 coats primer.
13. Sprayed 3 coats chrome - 12 minutes between each.
14. Sprayed 3-4 coats metallic blue. Get it as even as possible.
15. Drop it like a dumb ass and scratch it - New chrome and blue 1 coat each
16. Wipe down with alcohol
17. Set stencil and taped off - did a lot of work here with tooth pics and small brushes to touch up over spray and make perfect.
18. Used Sharpe to fill in the line between inner and outer parts with black.
19. Realized Sharpe didn't work for shit. Used small brush, paint, and patience to fill line in black.
20. Wiped down with alcohol to move dust.
21. coated with 3 even coats clear.
22a. Fuse box was the same process but a bit more taping and hand painting with tooth pics and brushes (little, tiny, wife's makeup brushes)
23a. Bought wife new makeup brushes and got her car washed, dog house avoided.
Mission complete:
Summary - if you like to tinker and have a vision, go for it, it was pretty fun. Not into the time and cursing needed, buy one and call it a day.
Yes, I served back in my youth. US Army. 6th ID Light, Alaska. HOOOAAAA.
If you gained any knowledge or even a giggle from this please take a moment of silence for our POW MIA soldiers. All gave some, some gave all, and because of them we are free. May you find your way home my brothers and sisters.
Thanks all,
Former Sgt. Dan
San Diego, CA
NowAChevyGuy
2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br]
Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now...
NowaChevyGuy is offline   Reply With Quote
Old 12-10-2017, 11:49 AM   #2
Stig eh
Drives: 2017 SS 50th Jan 17 2018
good stuff stig eh
Stig eh is offline   Reply With Quote
Old 12-10-2017, 11:53 AM   #3
wwiiavfan
Drives: 2017 1SS Hyper Blue
First of all thank you for your service, sir.
Second, looks great, great write up, including the goof ups!
Well done!
wwiiavfan is offline   Reply With Quote
Old 12-10-2017, 12:09 PM   #4
ac-427
Drives: 2018 Camaro 2SS Redline Convertible
Nice Job
2019 Buick TourX
2017 Colorado Redline
1966 Ford Mustang Pro Touring
ac-427 is offline   Reply With Quote
Old 12-10-2017, 12:49 PM   #5
4mulafastech
4mulafastech's Avatar
Drives: 2018 1SS 1LE
4mulafastech is offline   Reply With Quote
Old 12-10-2017, 05:44 PM   #6
scottc
Central PA Camaro5 Club
scottc's Avatar
Drives: Hot Wheels
Awesome bro !!
Hot Wheel SE # 343
scottc is offline   Reply With Quote
Old 12-10-2017, 09:57 PM   #7
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
I know it's not a professional job, but that is very damn impressive. Always great to see people do things on their own, especially when it turns out this good.
Congrats and thank you for your service!!!!
Old 12-10-2017, 11:05 PM   #8
Rooster OG
Rooster OG's Avatar
Drives: 2016
That looks killer, nicely done!
Rooster OG is offline   Reply With Quote
Old 12-10-2017, 11:14 PM   #9
NowaChevyGuy
Thanks,
I am a car guy to the core. Getting a little on in years I don't spend many weekends under them like I did back in the day but if there is something I can do myself I much prefer to give it a go first then just buy something. Idle hands tend to buy Ford's, or so I've heard, lol.
If you can walk away from it in the parking lot without looking back....
You bought the wrong car.
Thanks again all. Let me know if anyone has any questions or anything, glad to help.
NowAChevyGuy
Old 12-11-2017, 01:03 AM   #10
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
NICE!!
STYLO LT1 is offline   Reply With Quote
Old 12-11-2017, 02:11 AM   #11
Shorty45
Shorty45's Avatar
Drives: 2017 Summit White ZL1, M6
Great job man.That really does look great! Hooyah!
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396
Shorty45 is offline   Reply With Quote
Old 12-11-2017, 05:58 AM   #12
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
I've resembled this project many times, some failed, some succeeded. Thank's for the write up and your service. Semper Fi! Prayers sent. Nice looking work.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
Old 12-11-2017, 10:55 AM   #13
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I love the do it your self type jobs like this. Great work and write up.
BrianL is offline   Reply With Quote
Old 12-18-2017, 10:43 PM   #14
NowaChevyGuy
Thanks all
NowAChevyGuy
